script for www.dvd.nl ?
Harry
Post by Harry »
I've been testing around with scripts but I cannot make one for the website www.dvd.nl
It's A nice Dutch website with dvd-reviews .
My problem is that I know nothing about programming.
By trying to adjust other script I cannot let it find the right adress.
I wonder if someone can create me a script. or send me a script that is simular build up. So that I can adjust it easely?
the script should look at baseadress : http://www.dvd.nl/reviews.php
for the name of movie , go to that line & jump to position right after : href="http://www.dvd.nl/reviews.php?reviewid=
read the chars until it encounters char ' "> ' (its a number)
then it should go to the adress : http://www.dvd.nl/reviews.php?reviewid=xxx (where xxx = the chars(number) read above)
once on the page I think I can by copying from others scripts en adjusting some things let the rest work (finding year,producer ,actors etc..)
actually the base URL is :
http://www.dvd.nl/reviews.php?searchquery=
to what you can append the movie title for the search
thanks I will retry my attemps later on
Harry
Post by Harry »
I just can't get it to work,
can some help me just to the point where the sripts find the moviepage ?
I would appreciate it a lot.
The part of analyzing the moviepage should be no trouble .
My problems is just finding the movie page
Any help is welkom
In the returned page, just search for all the reviews.php?reviewid= strings. These are the ones to put in the Picklist (with http://www.dvd.nl/ added in front of them of course)
The return page seems not to be the valid one.
when I do the search then for "reviews.php?reviewid=" It only finds the films listed on the right site of the page without the found entries at the centre of the page.
I think the problems are :
that when the page opens the first time , the centre of the page is not the list of the found entries but an Ad.
In IE at the second time it display then right.
But when I build this in the script it end in an endless loop or it just finds no movies
Harry
Post by Harry »
Sorry forgot to login .
guest = Harry
This ad thing is a problem :/
It probably checks referers and/or cookies, but none is currently managed. For that you'll have to wait for a 4.x version of Ant Movie Catalog.
Harry
Post by Harry »
Ok, meanwhile I will search the net for other review pages in dutch en if finding one try to write a script for it.
