Connect different Catalogs
deathbyaclown
Post by deathbyaclown »
another suggestion I came up with.
I was inspired by the TV.com script viewtopic.php?t=2571
would it be possible to connect different catalogs.
E.g. I have a catalog with all my dvds. One entry is Friends. I have another catalog in which only all Friends episodes are stored in detail.
It would be fantastic if I could click (or anyhow) on the Friends entry in the DVD-catalog and can select the Friends catalog to get to the detailed catalog...
Hope this was understandable :(
It could be an easy solution for TV series... I'll think about that, thanks for the idea ;)
Morbid
Post by Morbid »
I'd prefer sub-grouping feature.
Something like that:
But there's seems to be problems with exporting movielist to another format.
Incubus
Post by Incubus »
I like the sub-category idea, and if you are going to use a seperate list for series, i know of a way to make te prog do the drop down listing
First copy in all episodes
then take and put say "Stargate Sg1" in the translated title of each ep
then if you organize by translated title, u will have the dropdown listing u are looking for
