[REL] Importing Series from TV.com (beta)
nalf
Post by nalf »
Hi all,
Here is a script to import episodes information from tv.com :
TV.com importation script
Features and limitations :
  • Imports title and episode number in the Original Title field in this format : <season>x<episode> - <title> (e.g. 1x1 - The One Where Monica Gets A Roommate)
  • Imports : Director, Year (based on the first airing), Category, Rating, URL, Description, Writer (in the Producer Field), Cast & Guest Stars (in the Actors field), Production Code (in the Comments field)
  • doesn't import the country because I couldn't find it on tv.com
  • doesn't import the length because tv.com isn't very accurate on this (e.g. anything from 45 mins to an hour will be listed as an hour)
  • can be very slow because the pages take forever to load - I get a lot of read timeouts. I guess it's because of tv.com - does anyone know if there's something I can do on my side ?
Scheduled improvements for next versions :
  • option to disable episode number importation or change the way it's imported
  • option to change where the guest stars are mentioned
  • options to import other things, like trivia, comments, etc...
  • update ability (right now you have to do the search all over again)
It would help a lot if some of you could test it on differents tv shows so that I'm sure it works.
Any new idea, comment or bug report is welcome !
Anne-Laure
Thanks ;)
Pko
Does not wrok with "Galactica"
Post by Pko »
I tried searching for the episode 1x02 of "Battlestar Galactica" (the new version of the show) and could not get it to work.
When I enter "Galactica" as the shown name and "Water" as de episode title, it correctly gives me three options for the show (Galactica 1980, Battlestar Galactica (2003) and Battlestar Galactica (1978)). I select de correct one but then (very quickley) it shows an empty results window for "Water"...
I tried with your example (show "Friends", episode "The One Where Monica Gets A Roommate") and it works very well, so I think it is a problem with the specific "Galactica" show.
Thank you very much
MOMAtteo79
Post by MOMAtteo79 »
testing it now. would be usefel for non en users (ie different episode titles) to import the complete list of episodes divide per season of a series and not just episodes one by one. would be even much more less entries in the database
nalf
Post by nalf »
Pko, I've just did exactly how you said and I got the correct result. I think you might have a problem with downloading the file. I'm afraid I can't really help you...
Matteo, I'll try to implement that in the next version. I'm not sure when I'll have the time to do it though - I have lots of work right now.
[PPr]Verstoerer
Post by [PPr]Verstoerer »
How can i import all episodes at once? Didn't work with no eps name, * or %
deathbyaclown
Post by deathbyaclown »
I dont know if this can help, but the eXtreme Movie Manager has a script to download all epsiodes from one series. One can have a look at it if you download the programm and go into the scripts directory.....
