Subtitles support
Subtitles support
Hello
Since a lot of us need subtitles to view our movies,we usually search & download the subtitles as an external file from web sites. It would be usufull to add a seperate field for the "Subtitle file link " which will point to a local/web link.
On that note since we search the subtitle file(s) on the net i would suggest adding a new Getfile function (same as GetPicture) to the scripting support .It will enable us writing scripts for search & import of subtitles file and storing them ( preferably EXTERNAL to the AMC catalog)
Why not. I'll see that in further versions, probably not 4.0, but maybe later.
LEXX
GOOD IDEA!
Post by LEXX »
That would be a GREAT improvement!!!
Also, for the script to search for pictures I would enjoy a script pointing at www.amazon.com for the dvd cover and some scripts pointing at some movie posters web site such as http://www.impawards.com/gallery.html. The more pictures, the better.
Would it be possible to put more than one picture for each movie in the database?
:grinking: BuyInSoft is dead, long life to AMC!
LEXX
don't act
Post by LEXX »
La prochaine version (4) permettra de mettre plusieurs images par film.
Pour les acteurs je verrai plus tard (bien plus tard) vu que pour moi c'est pas important et assez complexe à gérer
ANTP said YES: version four will allow more than one picture per movie.
Sorry, I was off topic anyway!
God, there is so much to read before I can post something new!
Image kisses
