Change number...
kinetix
Change number...
Post by kinetix »
Let's say that I want to change the number of a movie (call it A).
But the number is occupied by another movie (call it B).
As I see it now, I must first change the number of B, before I can change the number of A.
It would be really cool to see a feature that does this on auto.
I mean, that changes the number of B (to a free number) at the moment I change the number of A....
Do you follow me? ;)
Sure, it would be a nice idea... I'll write it on my list for next version (or later)
But how to change a single number without use a "Renumber" option in tools menu? Could you help mi? I can't find out what to do this. Thnx
Using menu Movie -> Change number (or press F2)
By the way, in version 3.5 rc5 the feature suggested above has been added.
