Rename - replace space space with space goes into weird mode
markusof
Post by markusof »
when replacing space space with space
everything after the space is appended - running multiple times results
source
test me
after
test me me
after another run
test me me me
Can you make a screen capture and/or give more details?
Is it with the "string replacement" action?
When I try, it does not do any change anything, as it says that old and new name are the same.
markusof
hmm
Post by markusof »
cannot seem to get it to do it..
this was on a buffalo nas, so I will try again..
