Could someone please point me in the right direction to start with the Designer? I can't seem to link it to my AMC movies database, or to pick up any data fields. I hope once I get a start I'll be OK.
Rob
Report Designer getting started
Re: Report Designer getting started
1) select some movieemueyes wrote:Hi,
Rob
2) from menu "File" select "print"
3) choose a template among those showed.
if there is no template you like, you can change one similar to your wishes and change it with "designer" on the menu.
It's almost simple to use designer, but there is no help about it (I think).
