Remove a standard field
MediaCult
Post by MediaCult »
I was wondering if there is the option of removing one of the standard fields for now? At the moment, I have imported by info from IMDB, including the "comments" field, which are comments from random IMDB users (ones I often don't agree with). I don't want these to be part of my catalog. How do I remove this field? I have catalogued more than 2500+ movies so manually is not an option.
When importing from a script you can uncheck the fields that you don't want using the list on the bottom-right of the script window.
However your question is rather for movies already imported if I understand well.
This can easily be done by script: go to Tools -> Scripting, run "Update fields", in the list one of the option is for deleting contents of a field.
