Renaming using Date and Time
arniegold
Post by arniegold »
This is a great feature, but I would love to also be able to use the "Taken" date in supported multimedia files, not only the Creation and Last modification date.
For jpeg it is possible using the Exif action
DarthMacAille
Post by DarthMacAille »
Hi everyone
First things first : thanks for your wonderful software I use for 6 years (more or less).
My question is fully related.
I usually use the 'Date & Time' Action to rename my pics and videos as :
yyyy'-'mm'-'dd'_'hh'-'nn (f)e
Normally, the modification date/time of the pics is the "date/time taken". But depending of the fact I had to rotate some pictures once on the PC, the modification time is the rotate time... and I did rotate before AntRenaming (I know, my bad :) ).
I then tried the EXIF (as said here) but unfortunatly, in this case, using %DateTimeOriginal% give the right time, but does not allow to format the date and time as the "Date & Time" Action allows to do (without seconds in my case).
Do you think it could be possible to integrate the choice 'Date taken' here :
In order to take profit of the full Date & time format options... ;)
Thanks in advance.
DarthMacAille
Found a solution
Hi again
after netdigging a little further, I have found several solutions to be able to change the "modified time" with the "date taken" date and time. Solving my issue.
Easiest way is using XNView. Tutorial here : http://www.luzphotos.com/logiciels/ligh ... date-photo, see the Changer la date d’une photo dans Xnview section.
DL XN View : http://www.xnview.com/fr/
See also a solution using Galerie de photos Windows :
http://www.commentcamarche.net/forum/af ... ise-de-vue
I'm not sure why this thread is in the "Ant Movie Catalog" section instead of "Ant Renamer", I didn't notice that back then.
Formatting options for Exif date/time is on my to-do list.
In the meantime, other solutions have to be used indeed.
Another possibility is to use regular expressions action to move/delete parts of the date/time once extracted from Exif.
e.g. viewtopic.php?t=6618
