Get targets from a text file
AKazak
Post by AKazak »
Greetings, dear community!
I have been using AR for the last 5 years and have only positive impressions. Carry on with the development of this wonderfully useful tool.
Recently I have been given a task to shorten long names of nearly 500 files with full path listed in a text file (one path - one line). Target files are located in different folders, so generic drag-and-drop procedure won't save time.
Can you suggest me a way to import this list of targets to AR instead of drag-and-drop procedure please?
Thank you very much for the prompt reply.
This is somewhere in the top of my "to do" list, but currently not possible with the current version.
AKazak
Post by AKazak »
I will be waiting for this simple, but powerful feature.
I appreciate if you notify once it is ready.
