I freshly reinstall a new windows 7 x64 on a new computer and I have a problem with AMC.
Some windows are void : http://imgur.com/GR7BrxH,SJGb14d#0 (there are 2 images, use Prev and Next button).
I think it's a missing functionnality which is not installed, but which one ?
Thanks in advance
Je viens d'installer windows 7 x64 sur un nouvel ordi et j'ai un problème avec AMC.
Certaines fenetres du logiciels n'affichent rien : http://imgur.com/GR7BrxH,SJGb14d#0 (Il y a 2 images, utiliser Prev et Next).
Il doit y avoir un programme dont AMC se sert et que je n'ai pas installé, mais lequel ?
Merci d'avance
[EN-FR]Some windows are void - Certaines fenetres sont vides
tdm
Raoul_Volfoni
It looks like an issue related to Windows theme or graphic driver.
The theme looks like something by default on Vista or 7 though.
I sometimes have similar problems with Delphi programs on Windows 8.1, but by passing the mouse over the window or move another window in front it forces the refresh in such case.
tdm
Well, uninstall and reinstall is the first thing I usually do, but I wanted to reinstall all my programs and I thought "I'll see this problem later".
This morning even before seeing the response I thought about it, and yes, it worked, no problem anymore.
Thanks for your responses !
Vu que je voulais réinstaller tous mes programmes je me suis dis "je verrais ça plus tard" sans penser à désinstaller et réinstaller ce programme.
Et ce matin avant même de voir la réponse j'y ai pensé, et effectivement ça marche, plus de problème.
Merci pour vos réponses !
