Need some advise/help for modifying PK moviesdb
pele
Post by pele »
Hi
1. Is there a way to change the value "true" in another text in the header?
Image[/url]
2. How do i correct the way i see the actors. See difference in the picture and website.
This is how i see it:
And this is the way how i see it at:
http://www.bclaude.neq3.com/index.php?view=MAINVIEW.
that looks correct.
3. How can i add 1 movie into the sql database because if i import the sql file with 1 movie then it overwrite the datase and i see only the one movie.
4. I modified the detail_view.tpl. I want the translated movie naam between (). I discoverd that i have to change something in mdb_movie.in somewhere in
     * Checks if ORIGINALTITLE = TRANSLATEDTITLE .
     * @access private
	function _viewtitles() {
	$html = "";
	$originaltitlte = trim($this->data[ORIGINALTITLE]);
	$translatedtitlte = trim($this->data[TRANSLATEDTITLE]);
	if ($translatedtitlte != $originaltitlte)
	$html .= "<div class='translated'>".$originaltitlte." <span class='title'> ".$translatedtitlte." </span></div>";
	$html .= "<div class='original'>".$originaltitlte."</div>";
	return $html;
But where?
Thanks Bianca
droopy57
Post by droopy57 »
I do not have time to checck everything.
But here is the answer for question 4 :
* @access private
$html = "";
$html .= "<div class='translated'>".$originaltitlte." <span class='title'> (".$translatedtitlte.") </span></div>";
return $html;
pele
Post by pele »
droopy57 wrote:I do not have time to checck everything.
* @access private
$html = "";
return $html;
Sorry droopy57 but your answer i allready tried. The fact is that a see in every title () and that is not what i want. I only want to see them if there is a translated title.
droopy57
Post by droopy57 »
Ah ok !
It's this is because you have empty 'translated titles'
So here
* @access private
$html = "";
if ($translatedtitlte != "")
return $html;
pele
Post by pele »
droopy57 wrote:Ah ok !
So here
* @access private
$html = "";
return $html;
Wow droopy57 that works :grinking: . Thanks.
Can you tell me what kind sript language this is because i couldn't find hat != means.
Stiil 3 issues to go :/
droopy57
Post by droopy57 »
It's php.
For your question 3 :
In AMC when you do your export sql.
You must uncheck the 3 checkboxes (on the right of the export window):
- "Update" instead of "Insert"
- "Drop table if exists"
- "Create table"
