AMC For Music
AMC For Music
Hi, I have been using AMC for years and it is a wonderfull programme. Is there any link to AMC for music. I am not so PC literate, so a simple download would be nice.
Regards
DAVEZN
Regards
DAVEZN
Re: AMC For Music
@davezn.
You can use normal AMC with the two scripts discogs and allmusic I wrote some time ago (you can find them in this sub-forum).
Re: AMC For Music
Thanks will have a look at them. Do you use a second version of AMC or just set up a different Catologue? Regards DaveZN
Re: AMC For Music
sorry, but i cannot find the script. Do you have instructions for the script and can you give me the link?
Kind Regards
Davezn
Kind Regards
Davezn
Re: AMC For Music
I use different catalogs (I have various catalogs for music, books, movies etc.) but it would be possible to use the same catalog with different values in field "Media Type".davezn wrote: 2018-04-03 07:02:43 Thanks will have a look at them. Do you use a second version of AMC or just set up a different Catologue? Regards DaveZN
Give us feedbacks, please.
Re: AMC For Music
sorted out a second catologue for music no problem with that, tested and fine for MP3's.
I just need the script for music.
Davezn
Davezn
Re: AMC For Music
please, what is the problem? Which kind of help do you need about this?davezn wrote: 2018-04-03 09:50:06 Hi,
Davezn
Scripts (allmusic & discogs) can be downloaded in this forum's section, as I said.
Search for them, please.
I don't know if there is any other script about music.
Re: AMC For Music
I found the script as below. I am not sure what parts I need, could you advise. Do I need it all or do i capy from where to where. Thanks for the help.
Authors=Fulvio53s03
Title=Discogs
Description=import album
Site=http://www.discogs.com
Language=IT, EN
Version=1.5.0
Requires=4.2.1.3
Comments=It can be used to search informations (mode=0) and to extract them to your AMC d.b. or to extract directly informations (mode=1), if you already know your album address' page in discogs. For a better selecting informations, you can also supply Artist's name in Original Title field and the information: CD, Album, LP ecc. in Media Type field. 2018.04.03 use https!
License=* The source code of the script can be used in |* another program only if full credits to Fulvio53s03 |* script
RequiresMovies=1
Mode=1|0|0=normal mode|1=batch mode (url)
[Parameters]
// TypeSearch=1|1|1=search for exact expression|2=search for any word
// TypeOrder=3|3|1=order by Artist|2=order by Album Title|3=order by relevance
// needs the following units
// StringUtils7552.pas
program discogs;
StringUtils7552;
discogsUrl = 'https://www.discogs.com'; // base url
//<div class="pagination_controls "> inizio links
//<div class="pagination bottom"> fine links
//<div class="cards cards_layout_large" id="search_results"> inizio struttura interna link
AllAlbumUrl = 'https://www.discogs.com'; // base url
batchlogfic = 'f:\discogs_batch.txt'; // log for batch mode
debug_search = false; // debug mode on/off su ricerca dischi
debug_album = false; // debug mode on/off su estrazione dati album
folder = 'f:\prova\'; // directory where to save files
inizio_e_fine_traccia = '<td class="tracklist_track_pos">';
inizio_credits = '<li>';
fine_credits = '</li>';
CRLFspace = CRLF + ' ';
nuovo_anno, mese_anno, solo_anno, data_rilascio, label: String;
Credit_address, Readdress, Page: String;
AlbumName, ArtistName, firstcall, abort, name, Dati_traccia, autori: String;
Formato, Releases, artista: String;
pag_ricerca, Commento, save_value, ordine_lista, Salva_autore: String;
value: string;
Album_ok: boolean;
BatchMode, index, lungo: Integer;
brani, Track, newtrack, old_track, datitrack: String;
titolo_e_autore, titolo, autore: String;
batchlog, confbatch: TstringList;
save_pag, artist, initchar, endchar: string;
albumok: boolean;
// list of albums
procedure GetList;
Address, urlmusic, album, albumtest, label, genre: String;
Save_address, Title_album, indir_album, indir_title_album: String;
Relevance, info_disco, artist_album, tipo_release, altri_dati: String;
dati_album, init_control, end_control: String;
Desc_ricerca: String;
ctr_loop: integer;
found: boolean;
i, lgth_dati_album, lgth_pag_ricerca: integer;
// https://www.discogs.com/search/?q=bitches+brew
PickTreeClear; // clear list
// https://www.discogs.com/search/?q=Symphony+X&type=all
//fs20150727 Address := discogsUrl + '/search/?q=' + UrlEncode(AlbumName) + '&layout=sm'; //fs
// Address := discogsUrl + '/search/?q=' + artista + ' ' + AlbumName + '&layout=sm'; //fs20150727
Address := discogsUrl + '/it/search/?q=' + artista + ' ' + AlbumName + '&layout=sm'; //fs20160412
// Address := Address + '&lang_alt=en';
//fs2015.06.10 Address := discogsUrl + '/search/?q=' + AlbumName + ' ';
//fs2015.06.10 Address := Address + ArtistName + '&format_exact=' + formato + '&layout=sm'; //fs
// Address := discogsUrl + '/search/?q=' + AlbumName + '&type=all'; //fs2015.06.10
Address := UrlEncode(Address);
Desc_ricerca := '"' + AlbumName + '"';
if length(ArtistName) > 0 then
Desc_ricerca := Desc_ricerca + ', ' + ArtistName;
if length(formato) > 0 then
Desc_ricerca := Desc_ricerca + ', ' + formato;
Page := GetPage(Address);
Save_address := Address;
HTMLdecode(Page);
found := False;
// PickTreeAdd('List of albums found for' + '"' + AlbumName + '"', '');
PickTreeAdd('List of albums found for ' + Desc_ricerca, '');
if debug_search then
DumpPage(folder+'discogsList.txt', Page); // debug
if Pos('find anything', Page) <> 0 then
LogMessage('Error while reading selection page - no results found for ' + Desc_ricerca);
init_control := '<div class="pagination_controls ">';
end_control := '<div class="pagination bottom ">';
info_disco := '<div class="card_body">';
pag_ricerca := init_control + TextBetween(Page, init_control, end_control) + end_control; //elenco titoli richiesti
lgth_pag_ricerca := length(pag_ricerca);
Normalizza_Page(pag_ricerca);
save_pag := pag_ricerca;
DumpPage(folder+'discogs_pag_ricerca.txt', pag_ricerca); // debug
dati_album := info_disco + TextBetween (pag_ricerca, info_disco, info_disco) + info_disco;
//dati_album contiene recursivamente i dati degli album
lgth_dati_album := length(dati_album);
DumpPage(folder+'discogs_dati_album.txt', dati_album); // debug
delete(Pag_ricerca, 1, length(dati_album) - length(endchar));
ctr_loop := 0;
lungo := (Length(info_disco) + length(info_disco));
while (lgth_dati_album > Lungo) and (ctr_loop < 50) do //estraggo al massimo 50 titoli
ctr_loop := ctr_loop + 1;
initchar := '<a class="search_result_title';
endchar := '</a>';
indir_title_album := textBetween(dati_album, initchar, endchar) + endchar;
initchar := 'href="';
endchar := '"';
Address := discogsUrl + textBetween(indir_title_album,initchar, endchar);
initchar := '<a href="/artist';
endchar := '</span>';
artist_album := textBetween(dati_album,initchar, endchar); //Artista
initchar := '>';
endchar := '<';
artist_album := textBetween(artist_album,initchar, endchar); //Artista
initchar := '>';
endchar := '</a>';
Title_album := textBetween(indir_title_album,initchar, endchar); //titolo dell'album
initchar := '<p class="card_status">';
endchar := '</p>';
tipo_release := textbetween(dati_album, initchar, endchar);
tipo_release := FormatText(tipo_release); //tipo release
initchar := '<p class="card_info">';
endchar := '</p>';
altri_dati := textbetween(Dati_album, initchar, endchar);
altri_dati := FormatText(altri_dati);
Title_Album := artist_album + ' - ' + Title_Album + ' (' + tipo_release + ', ' + altri_dati + ')';
Title_Album := stringreplace(Title_Album, CRLF, '');
Title_Album := stringreplace(Title_Album, ' Needs Vote,', '');
PickTreeAdd(Title_Album, Address);
found := True;
delete(Pag_ricerca, 1, lgth_dati_album);
Pag_ricerca := Pag_ricerca + info_disco; //fs 2015_01_12
lgth_pag_ricerca := length(Pag_ricerca);
dati_album := info_disco + TextBetween (pag_ricerca, info_disco, info_disco); //recursivamente i dati degli album
lgth_dati_album := length(Dati_album);
if not found then
LogMessage('No album found for '+AlbumName);
AnalyzeMusicPage(Address); // Album page
LogMessage('No album selected');
// ANALYZE MUSIC PAGE
procedure AnalyzeMusicPage(Address: string);
urlmusic, cover, Lenght, Pays: String;
Autore, style, Commenti, str_min, campo_note: String;
minu, minuti, ore, lgth_comm, save_lgth_comm, i: integer;
j: Real;
Page := UTF8decode(Page);
if debug_album then
DumpPage(folder+'discogsPageDetail.txt', Page); // debug_album
HTMLdecode(Page);
if debug_album then
DumpPage(folder+'discogsPageDetailHTMLdecode.txt', Page); // debug_album
Readdress := '';
Readdress := textbetween(Page, '<meta property="og:url" content="', '">');
if length(Readdress) > 0 then
Address := Readdress;
if Pos('<div class="head">', Page) = 0 then //inizio dati da estrarre
Begin
LogMessage('Pagina album errata - Error while reading album page');
Normalizza_Page(Page);
// Page := UTF8Decode(Page); //fs2015-01-15
albumok := True;
//dati generali
initchar := '<div class="profile">'; //io info generali
endchar := '<div class="section_content">'; //inizio tracklist
Value := TextBetween(Page, initchar, endchar);
if debug_album then
DumpPage(folder+'discogsinfo_generali.txt', Value);
initchar := '<div class="head">Label:</div>';
endchar := '</div>';
label := textbetween(value, initchar, endchar) + endchar;
HtmlRemoveTags(label);
label := StringReplace(label, CRLF, '');
label := fulltrim(label);
// label := StringReplace(label, '‎', '');
// label := StringReplace(label, '–', '');
label := StringReplace(label, ' ', ' ');
SetField(fieldproducer, label);
label := textbetween(Value, '<span itemprop="name" title="', '"');
SetField(fieldoriginalTitle, label); //artista in original title
initchar := '<span itemprop="name">';
label := textbetween(Value, initchar, endchar);
SetField(fieldtranslatedTitle, label);
initchar := '<div class="head">Format:</div>'; //formato LP/Album/CD/ristampa ecc.
label := textbetween(Value, initchar, endchar) + endchar;
label := FormatText(label);
label := stringReplace(label, CRLF, '');
label := stringreplace (label, ' ', ' ');
SetField(fieldvideoformat, label); //formato
label := textbetween(Value, '<div class="head">Country:</div>', endchar) + endchar;
SetField(fieldcountry, label); //paese
label := textbetween(Value, '<div class="head">Released:</div>', endchar) + endchar;
SetField(fieldyear, label);
//fs20150728 estrazione data della release
nuovo_anno := getfield(fieldYear); //fs20150728 //anno
if length(nuovo_anno) = 0 then
estrai_data_released;
// end;
label := textbetween(Value, '<div class="head">Genre:</div>', endchar) + endchar;
style := textbetween(Value, '<div class="head">Style:</div>', endchar) + endchar;
style := FormatText(style);
if length(style) > 0 then
label := label + ' (' + style + ')';
SetField(fieldcategory, label); //genere
//discogs tracklist
initchar := 'id="tracklist" class="section tracklist" data-toggle="tracklist">';
endchar := 'class="section credits toggle_section toggle_section_remember"';
if length(Value) = 0 then
endchar := 'class="section notes toggle_section toggle_section_remember"'; //inizio note;
endchar := 'class="section_content toggle_section_content">'; //inizio note;
endchar := 'section notes'; //inizio note;
initchar := '<td class="tracklist_track_pos">';
endchar := '</table>';
Value := initchar + TextBetween(Value, initchar, endchar) + inizio_e_fine_traccia;
if debug_album then
DumpPage(folder+'discogstracks.txt', Value);
brani := '';
estrazione_tracce;
// value := stringReplace(brani, '–', '');
value := stringreplace(brani, 'Composed By', ' - composed by');
value := stringReplace(value, '*', '');
// value := stringReplace(value, '&', '&');
//*** artists
initchar := 'class="section credits';
endchar := '<!-- /credits -->';
initchar := '<div class="section_content toggle_section_content">';
value := TextBetween(value, initchar, endchar);
if debug_album then
DumpPage(folder+'discogscredits.txt', Value);
brani := '';
estrazione_credits;
value := brani; //fs2015.01.21
value := stringreplace(value, ' ', ' '); //fs2015.01.21
SetField(fieldActors, value);
//*** note
initchar := 'class="section notes';
endchar := 'class="section m_versions';
value := TextBetween(Page, initchar, endchar);
value := FormatText(value);
initchar := 'class="section notes toggle_section toggle_section_remember"'; //inizio note
endchar := '<!-- /notes -->'; //fine note
initchar := 'class="section_content toggle_section_content">';
campo_note := value;
//*** barcode
initchar := 'class="section barcodes toggle_section'; //inizio note
endchar := '<!-- /barcodes -->'; //fine note
initchar := '<ul class="list_no_style">';
endchar := '</ul>';
// HTMLRemoveTags(value);
value := stringReplace(value, CRLFspace, CRLF);
if (value = 'Barcode:') or (value = 'barcode:') then
value := '';
commenti := '';
if length(campo_note) > 0 then
commenti := campo_note;
if length(value) > 0 then
commenti := commenti + CRLF + value;
commenti := value;
// end;
// end;
if length(data_rilascio) > 0 then
commenti := 'Released on ' + data_rilascio + CRLF + commenti;
SetField(fieldComments, commenti);
data_rilascio := '';
//*** cover
//2018.04.02 cover := TextBetween(Page, 'data-images=', '"full"');
cover := fulltrim(TextBetween(Page, '<span class="thumbnail_center">', '</span>')); //2018.04.02
cover := fulltrim(TextBetween(cover, '<img src="', '"')); //2018.04.02
//2018.04.02 initchar := '"https:';
//2018.04.02 endchar := '"';
//2018.04.02 cover := initchar + TextBetween(cover, initchar, endchar);
//2018.04.02 cover := discogsUrl + cover;
if CanSetPicture then
GetPicture(cover);
Procedure estrazione_tracce;
lgth_track: integer;
Begin
// normalizza_page(Value); //fs2015.01.15
initchar := inizio_e_fine_traccia;
endchar := inizio_e_fine_traccia;
lungo := (Length(initchar) + length(endchar));
Dati_traccia := initchar + TextBetween(Value, initchar, endchar) + endchar;
while Length(Dati_traccia) > Lungo do //esegui se trovato qualcosa
datitrack := '';
track := '';
endchar := '</td>';
datitrack := textbetween(dati_traccia, initchar, endchar) + ' '; //n.d'ordine
lgth_track := length(datitrack);
if lgth_track = 2 then //num.traccia <10
datitrack := '0' + datitrack + ' ';
initchar := '<td class="tracklist_track_artists">';
endchar := '</td>';
track := textbetween(dati_traccia, initchar, endchar); //artista in antologie
HTMLRemoveTags(track);
if length(track) > 0 then
datitrack := datitrack + ' ' + track + ' - ';
initchar := '<span class="tracklist_track_title" itemprop="name">';
track := textbetween(dati_traccia, initchar, endchar); //titolo brano
datitrack := datitrack + track;
initchar := '<blockquote>';
endchar := '</blockquote>';
track := stringReplace(track, '<span class="tracklist_extra_artist_span">', '<span class="tracklist_extra_artist_span"> ');
datitrack := datitrack + ' (' + track + ')';
initchar := 'class="tracklist_track_duration">';
endchar := '</td>';
track := textbetween(dati_traccia, initchar, endchar); //durata brano
track := StringReplace(track, CRLF, '');
track := FullTrim(track);
// dati del brano raccolti in datitrack
datitrack := stringReplace(datitrack, '( ', '(');
datitrack := stringReplace(datitrack, 'ritten-', 'ritten ');
datitrack := stringReplace(datitrack, '–', '');
datitrack := stringReplace(datitrack, '*', '');
if length(datitrack) > 3 then
brani := brani + datitrack + CRLF; //fs 2014.11.15
// reimposto l'area su cui loopare
delete(Value, 1, length(Dati_traccia) - length(inizio_e_fine_traccia));
dati_traccia := initchar + TextBetween (Value, initchar, endchar) + endchar; //dati_album contiene i dati dell'album
//fs ********************* fine estrazione tracce *****************************************
Procedure estrazione_credits;
oldtrack: string;
Begin
initchar := inizio_credits;
endchar := fine_credits;
oldtrack := '';
datitrack := '';
track := '';
initchar := '<span class="role">';
datitrack := textbetween(dati_traccia, initchar, endchar) + ' '; //ruolo
initchar := 'class="rollover_link">';
endchar := '</li>';
if length(track) = 0 then
initchar := '</span>';
track := FormatText(track);
datitrack := datitrack + ': ' + track; //nomi
datitrack := stringReplace(datitrack, '*', ''); //fs2015.01.21
if track <> oldtrack then
oldtrack := track;
delete(Value, 1, length(Dati_traccia) - length(inizio_credits));
//fs ********************* fine nuova estrazione credits *****************************************
Procedure Normalizza_page(Pagina: string); // elimina i crlf, trasforma delimiters maiuscoli in minuscoli
pagina := RegExprSetReplace('<([^>]+)>', pagina, '<\L\1>', true);
CharAbNormal := crlf;
CharNormal := ' ';
pagina := StringReplace(pagina, CharAbNormal, CharNormal);
CharAbNormal := '<B';
CharNormal := '<b';
CharAbNormal := '</B';
CharNormal := '</b';
pagina := StringReplace(Value, CharAbNormal, CharNormal);
CharAbNormal := '<FONT';
CharNormal := '<font';
CharAbNormal := '</FONT';
CharNormal := '</font';
CharAbNormal := '<TR';
CharNormal := '<tr';
CharAbNormal := '</TR';
CharNormal := '</tr';
CharAbNormal := '<TD';
CharNormal := '<td';
CharAbNormal := '</TD';
CharNormal := '</td';
CharAbNormal := '<DIV';
CharNormal := '<div';
CharAbNormal := '</DIV';
CharNormal := '</div';
if BatchMode > 0 then
ShowWarning(m);
batchlog.Add(m);
batchlog.SaveToFile(batchlogfic);
// process batch mode
procedure discogsBatch;
AlbumName := GetField(fieldUrl); // if no url or another site then ignore
Albumname := stringreplace(Albumname, 'http://', 'https://'); //2018-04-02 oldaddresses
// if (AlbumName <> '') and (Pos(AllAlbumUrl, AlbumName) > 0) then
AnalyzeMusicPage(AlbumName);
// else
// LogMessage('ignored url="'+AlbumName+'"');
procedure estrai_data_released;
// ShowMessage('data di rilascio ' + nuovo_anno);
label := StringReplace(label, ' ', '/');
data_rilascio := label;
mese_anno := Textafter(data_rilascio, '/');
solo_anno := Textafter(mese_anno, '/');
// if length(campo_note) > 0 then
// begin
// commenti := campo_note;
// if length(value) > 0 then
// begin
// commenti := commenti + CRLF + value;
// end
// end
// else
// commenti := value;
if length(solo_anno) > 0 then
setfield(fieldyear, solo_anno);
// process normal mode
procedure discogsNorm;
albumok := False;
AlbumName := GetField(fieldTranslatedTitle); // get album name
ArtistName := getField(fieldOriginalTitle); // get artist
confbatch := TStringList.Create;
confbatch.Add('You have selected the normal mode:');
confbatch.Add('if You supply artist name in Original Title field,');
confbatch.Add('I will search discogs database using both');
confbatch.Add('artist and album name.');
confbatch.Add('Results will be more accurate!');
confbatch.Add('');
confbatch.Add('confirm your choice');
if not ShowWarning(confbatch.Text) then
AddToLog('batch mode aborted'); // batch mode not confirmed = abort
abort := 'o';
// if not Input('discogs - ' + Value, 'Enter the name of the album :' + crlf, AlbumName) or (AlbumName = '') then exit;
if not Input('discogs = ' + ArtistName + ' - ' + AlbumName, 'Enter the name of the album :'
formato := getfield(fieldmediatype);
if pos(formato, 'cd') > 0 then
formato:= 'CD';
artista := Artistname;
GetList;
until albumok;
// start here
if abort = 'o' then exit; // batch mode aborted
if firstcall <> 'done' then
begin // 1st call: init parameters
firstcall := 'done';
if not CheckVersion(4,2,1) then
ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 4.2.1.3)');
abort := 'o';
if BatchMode > 0 then // batch mode: confirm the choice
batchlog := TStringList.Create; // init batch log
batchlog.Add('starting batch mode');
batchlog.Add(StringOfChar('*',80));
// confirmation message
confbatch.Add('You have selected the batch mode:');
confbatch.Add('Did you save your database?');
confbatch.Add('*** Address to extract must be supplied in Field Url ***');
confbatch.Add('');
confbatch.Add('At the end of treatement:');
confbatch.Add('- look at the file ' + batchlogfic + ' for errors/infos');
confbatch.Add('- the albums found will be checked, the others not (for the selection)');
confbatch.Add(' (see: Tools/Preferences/Movie list/checkboxes)');
confbatch.Add('');
abort := 'o';
// let's go
if BatchMode = 0 then
discogsNorm
discogsBatch;
Authors=Fulvio53s03
Title=Discogs
Language=IT, EN
Version=1.5.0
Requires=4.2.1.3
RequiresMovies=1
[Parameters]
program discogs;
StringUtils7552;
value: string;
Album_ok: boolean;
albumok: boolean;
// list of albums
procedure GetList;
ctr_loop: integer;
found: boolean;
HTMLdecode(Page);
found := False;
ctr_loop := 0;
endchar := '</a>';
endchar := '"';
initchar := '>';
endchar := '<';
initchar := '>';
endchar := '</a>';
endchar := '</p>';
endchar := '</p>';
found := True;
if not found then
j: Real;
if debug_album then
HTMLdecode(Page);
if debug_album then
Readdress := '';
Begin
albumok := True;
//dati generali
if debug_album then
// end;
//discogs tracklist
if debug_album then
brani := '';
estrazione_tracce;
//*** artists
if debug_album then
brani := '';
estrazione_credits;
//*** note
//*** barcode
endchar := '</ul>';
value := '';
commenti := '';
commenti := value;
// end;
// end;
//*** cover
GetPicture(cover);
Begin
datitrack := '';
track := '';
endchar := '</td>';
endchar := '</td>';
endchar := '</td>';
oldtrack: string;
Begin
oldtrack := '';
datitrack := '';
track := '';
endchar := '</li>';
oldtrack := track;
CharNormal := ' ';
CharNormal := '<b';
ShowWarning(m);
batchlog.Add(m);
// else
// begin
// begin
// end
// end
// else
albumok := False;
confbatch.Add('');
abort := 'o';
formato:= 'CD';
GetList;
until albumok;
// start here
abort := 'o';
confbatch.Add('');
confbatch.Add('');
abort := 'o';
// let's go
discogsNorm
discogsBatch;
Re: AMC For Music
Discogs script: as usual,
1) in folder Scripts create a discogs.ifs file (if not exist)
2) open it with windows noteblock
3) copy complete code inside
4) save as "allfiles" (it must mantain .ifs file estension.
done!
N.B. fields are recognized in Italian language. This is the language you must set in your discogs account.
Allmusic script: same procedure as discogs but no problem about language (English only!).
done!
Re: AMC For Music
Thank you very much, the all music script now works.
One last question when running it asks for name of the album, as i dont know the album how can this be changed as i have the song name only not the album name.
Kind Regards
David
Kind Regards
David
Re: AMC For Music
You cannot supply the "song name" as obviousely you will have different results than using an "Album Name".davezn wrote: 2018-04-06 09:25:54 Thank you very much, the all music script now works.
Kind Regards
David
At the moment the script searches only album name (that can even be the same as song name).
To search single songs I suggest you to use the bath option of the script (after having a "manual" search on allmusic.com).
Maybe one day i will make a variant to the script (if possible) .....
Re: AMC For Music
I'm sorry.
I prepared a script to extract individual song information from allmusic but the extractable data are so thin that I abandoned it.
To understand, for example, by searching for "Light my fire" check the pages:
w_w.allmusic.com/song/light-my-fire-mt0050130739
w_w.allmusic.com/song/light-my-fire-mt0005605484
w_w.allmusic.com/song/light-my-fire-mt0011587030.
I will not continue.
Re: AMC For Music
many thanks for the reply and all of your efforts, very much appreciated.
"Continui il GRANDE LAVORO, è bery molto apprezzato. Grazie."
Nelsonhayes
Re: AMC For Music
I usually use Spotify to listen to music, not AMC. If necessary, you can try installing it at: https://spotify-apk.es.modfyp.com
