[BETA Template with pictures]
J
Post by J »
hi there,
I tried to make a more colorful template with some pictures for the HTML-viewer.
Currently it´s more or less a technical preview with a prototype layout and a couple of preparations have to be done by hand before you get this template running.
There are also still some restrictions regarding the picture handling, but soulsnake will perhaps make this more comfortable in the future.
It´s including the color tags (as a colored box), which I personaly use for my own movie rating.
Unfortunately there is neither JS nor CSS3 support, so do not expect any stylish dynamic goodies.
So if somebody have a suggestion then pls. tell me, I´ll post this template after some more CSS tuning.
have a nice day.
J
REL: Blue with pictures
Post by J »
hi all,
this is a bunch of HTML-view templates using up to 5 additional stills. The layout is much the same and can easly be changed.
Using the picture templates is as easy as every other template, but you have to do a couple of things first.
Don´t worry, you need to do this only once and it looks much more complicate than it is.
*** PART 1 - Picture handling (in 1 minute without picture copying)
1) Create a directory which will later contain all your movie pictures.
2) Create a subdirectory for EACH movie named by the movie number (e.g. "1560" for movie number 1560)
-- OK, at this point you´ll think "what the hell...", but stay calm, the little batch file (makedirs.bat) from the package will do this automaticly for you in 1 sec.
-- You know how to work with a batch file, don´t you? --> Sure you do, otherwise do this:
-- Open makedirs.bat with you favorite text editor or right-click & edit.
-- In the first line change the HIGHEST movie number (e.g. Number=300)
-- In the second line change LOWEST movie number - 1 (e.g. Start=0)
-- SAVE the batch file in your PICTURE DIRECTORY from above!
-- Double click the batch file, it will then create 300 subdirectories named from 1 to 300.
3) Copy your movie pictures(jpg-format) to the corresponding movie subdirectory. (Don´t care about the names but about the size!)
-- You can don´t need to do this for all movies at once.
4) Now use "Lupas Rename" for complete automatic renaming. It is free and a very useful programm. (http://rename.lupasfreeware.org/)
-- You can rename ALL your hundreds of picture files including ALL subdirectories at once with 1 click! - Exactly what you need here.
-- HAVE A LOOK at the included example picture(lupas.jpg) first to see how to rename! (There is an english version of the program.)
-- Use a different catalog name for each catalog you have.
You´re done! - with part 1 ;)
Info:
- For large catalogs with thousands of pictures it is a must to use the tools and also a batch picture tool like free "FastStone Photo Resizer".
- Of course, all the efforts are depending on the amount of movies and pictures you have.
- It´s also a good idea to keep the size of your pictures small to prevent long loading times while browsing through your movies.
- The pictures can NOT be stored in the catalog.
- REMEBER: Renumbering your movies in the catalog needs a renumbering of your picture directories and names! Not a good idea at all.
*** PART 2 - preparing your catalog (you can do this two ways in 1 minute)
First possibility:
1) open the dummy catalog (Dummy.amc).
2) Edit the custom field "Picture Path" and set the default value to your picture path without the last backslash (e.g. D:\My movie pictures).
-- (you can later add some more paths to the list value if you like or change the path with "update fields" script in AMC.)
3) Edit the custom field "catalog name" and set the default value to the catalog name you used before with Lupas Rename.
4) Import your existing catalog.
5) Save the catalog to a new name.
6) Choose one of the templates(3/5 pictures) in HTML-view.
Second possibiliy:
1) Make a BACKUP of your catalog! Open your catalog.
2) Add a new custom field and type "PIC_PATH" (without quotes) into the tag field. Press the green plus button then OK.
3) Add a new custom field and type "CATALOG" (without quotes) into the tag field. Press the green plus button then OK.
4) Open script window, select all movies and click "update fields"-script, then choose "replace a field".
-- choose "PIC_PATH". Confirm then type in/copy your picture path (without the last backslash!). Wait for some seconds to process.
-- Now the "PIC_PATH"-field should be filled with your picture path for all movies.
-- Do the same for "CATALOG".
5) Save your catalog.
That´s all!
All the needed files, including this text and some example pictures.
Unpack the templates and the background.gif to your template directory, the catalog to your catalog dir.
http://www41.zippyshare.com/v/18538776/file.html
HINT:
- If you prefer to have all your pictures in only ONE directory, you can now move them to your picture dir (Win-search all *jpg from pic dir, then copy).
Use template "3/5 pictures - one dir". That´s it.
- When you later want to add some more pictures, do again PART 1(step 2-4) and sort files in Lupas by date so you can select the new pics only.
- You can do this for more than one catalog in the same directory, just use diffent catalog names.
- I also added a template (basic.html) if you don´t like pictures and are still awake ;)
good luck & enjoy
Image Image Image
PS: You can of course use Antoines renamer as well, but I don´t have a clue how it works. so you may ask Antoine for this.
I uploaded the file to https://forum.antp.be/users/J/ in case it disappear in the future ;)
(since after some time that happens on these free hosts)
J
Post by J »
Hi there,
just some more small templates with additional pictures.
This time you can use a picture as background for the upper part of the template. The idea was to show a big picture with another picture and some text on top of it.
Contrary to a normal background pic, the picture will be sized automaticly widthways and shown only once without tiling.
To avoid an unreadable text, you can easily change the text color for each movie in a custom field. Just type in the RGB-color code (e.g. AAC6D8) and have a look.
You need to have the backgrund pic in format CATALOGNAME_MOVIENUMBER_B.jpg (e.g. FILME_456_B.jpg).
You also can choose a path for the pic in a custom field.
You´ll find an example catalog with pictures and all templates in the attachment.
That´s all, have fun.
Example catalog:
http://www47.zippyshare.com/v/81830285/file.html
Examples:
Image Image Image Image
J
Post by J »
Small update to the former template for the new AMC v4.2
If you want to work with the new movie extras, you can use these pictures in the adapted template very easy. Just add your pictures in the extras, that´s all!
Do not use more than 5 pictures because the template´s layout will get otherwise corrupt. It might be a good idea to size the pictures to a max. of 480x270 for fast template loading.
Blue 5 for v4.2.zip
Post by soulsnake »
Hi J,
Thanks for your update for AMC 4.2.
If you want to limit the number of extras displayed in HTML template to 5 you can specify it in template like this:
$$ITEM_EXTRA_BEGIN(,,1,5)
<img class="pics" src="$$ITEM_EXTRA_PICFILENAME" alt="Missing $$ITEM_EXTRA_URL">
$$ITEM_EXTRA_END
Also, you can filter displayed extras by category and/or by extras checked or not like this:
$$ITEM_EXTRA_BEGIN(MyCategory,True,1,5)
$$ITEM_EXTRA_END
J
Post by J »
Ahh, very well, I´ll use this for an update of whole blue templates and a new one I´m currently working on.
thanks.
