It,s possyble to add fields or modify name or the existing?
RANICUAJO
Post by RANICUAJO »
Hello
I don´t use some fields, but i want to add another ones
It is possyble?
Thanks for this great software
:grinking:
You can change the names of the fields by editing the translation files.
Open the one that you use from the "Languages" folder using a text editor (e.g. Notepad) and search for the [TMovieFrame] section.
Note that if you do that with English.lng you have to select "English (for translations)" as language instead of "English (default)".
RANICUAJO
Post by RANICUAJO »
A million of thanks antp :grinking:
I will try it.
I was thinking in a field to register if the movie was viewed, or is part of a saga....
thanks again
RANICUAJO
Post by RANICUAJO »
hi antp
I'm tried it and works fine in the program main window, but in the menus, the fields names keeps the previous.
For example, i changed the field "source" for the field "state", but when i want to sort the list by this field, i don´t see "state". I see "source".
It's possyble to change it?
Thanks again, and sorry for my bad english :hum:
RANICUAJO
Fichero de Traducción de AMC al español opcional
Post by RANICUAJO »
Existen algunos campos originales del AMC que yo no utilizaba, y que he renombrado, para darles un nuevo uso
campo "prestatario" cambia a "estado" para definir si la película se ha visto o no
campo "fuente" cambia a "opinión" para valorar la película después de vista como muy buena, buena...
campo "idiomas" cambia a "grupos, sagas" para definir si la película es parte de una saga, una secuela, una serie...
campo "subtitles" cambia a "Características Principales" para definir la película en unas palabras
Adjunto el fichero de lenguage, por si a alguien le interesa la modificación.
Para ello bastaría con sustituir el fichero spanish.lng de la carpeta ant movie catalog/languages , con el incluido en el zip
Now I understood
This Is the result
and the language file to download (spanish)
http://www.mediafire.com/?gapcf3nug8vtdnk
Thanks antp
I guess that you found it in the meantime, but indeed I forgot to mention that menus etc. are elsewhere in the file.
