[RESOLU] Erreur de script !
divxdvd
Post by divxdvd »
voilà le souci...
J'ai voulu jouer au "kador" et je me retrouve au final avec au final:
- memory out ?
- I/O error 32
J'ai du faire une erreur de script bien sur !
- D'ailleurs comment faire pour inclure un tableau dedans ?
merci pour l'aide à venir !
le script trafiqué:
:cry:
<html><head>
<style TYPE="text/css">
text,body,p,div,span,th,td,ul,li { FONT-SIZE: 10pt; FONT-FAMILY: Trebuchet MS, Verdana, Arial, Helvetica, sans-serif; color: black; background: white; }
HR { color: black; }
A:link { COLOR: #003399; background: white; }
A:visited { COLOR: #003399; background: white; }
A:hover { COLOR: #CC0000; background: white; }
A:active { COLOR: #CC0000; background: white; }
td.blk { color: white; background: black; border: solid; border-color: black; }
table.blk { color: white; background: black; border: solid; border-color: black; border-width: thin; }
table.lgt { color: black; background: white; border: solid; border-width: thin; border-color: #F5F5F5; }
td.lgt { color: black; background: white; border: solid; border-width: thin; border-color: #F5F5F5; }
p.title { font-size: 18pt; font-weight: bold; }
</style></head><body>
<p>Catalog created on $$DATE with <a href="http://www.antp.be/software/moviecatalog/" target="_blank">Ant Movie Catalog</a>.</p>
<table class="blk" border="1" cellspacing="0" cellpadding="5"><tr>
<td class="blk" nowrap>Numéro</td>
<td class="blk" nowrap>Titre</td>
<td class="blk" nowrap>Categorie</td>
<td class="blk" nowrap>Oukilé</td>
</tr>$$ITEM_BEGIN<tr>
<td rowspan="2" class="lgt"><strong>$$ITEM_NUMBER $$ITEM_APPRECIATION<br>$$ITEM_PICTURE</strong></td>
<td class="lgt">$$ITEM_TRANSLATEDTITLE </td>
<td class="lgt">$$ITEM_CATEGORY </td>
<td class="lgt">$$ITEM_MEDIA </td>
<td class="lgt">$$ITEM_SUBTITLES </td>
</tr><tr><td colspan="6" class="lgt">$$ITEM_DESCRIPTION </td></tr><tr><td colspan="7" class="blk"></td>
</tr>$$ITEM_END</table><p><strong>Total: $$TOTALMOVIES movies</strong></p></body></html>
divxdvd
Post by divxdvd »
En fait, ça marche mais il a juste fallut que j'étaigne et redémarre le logiciel !
merci !
par contre, je suis toujours à la recherche pour un tableau !
Le tip top serait un fichier template en html avec le choix recherche films, le nombre de films...
Bref je remercie toutes les propositions.....
bonne journée à toutes et tous
Raoul_Volfoni
Post by Raoul_Volfoni »
Salut divxdvd
divxdvd wrote:par contre, je suis toujours à la recherche pour un tableau !
D'après ce que je comprends ... ;) ... tu n'es pas dans la bonne section du forum pour poser ta question.
Ici on parle de scripts (pour la récupération de données) or ce que tu sembles rechercher est du domaine du modèle d'export en HTML, autrement dit un "Template".
Antp pourra certainement déplacer ton post dans la section adéquat, en attendant je te laisse jeter un coup d'oeil à la section Template du forum où tu pourras très certainement trouver ton bonheur.
Je ne peux moi même pas faire grand chose pour toi n'étant pas du tout familiarisé avec l'export en HTML.
divxdvd
Post by divxdvd »
ok, merci et mille excuses pour le mauvais rangement...
Je pensais que c'était un script !!! :cry:
Outch !
bonne journée ;)
Voilà c'est déplacé vers la bonne section.
Par contre pour la question... je ne vois pas trop quoi répondre. Il y a déjà un tableau dans ce que tu donnes ci-dessus. Donc qu'appelles-tu "tableau" ?
divxdvd
Post by divxdvd »
Ok et mille excuses pour le mauvais positionnement de ma demande...
J'ai re-bidouillé quelque peu et je pense avoir trouvé quelque chose de potable.....
Mais bon c'est toujours pareil, quand on offre la main, on aimerait bien "manger" le bras...
Je veux dire par là, plus de choix de recherches, par types, catégories, etc...
du style de Nenesse, que l'on peut trouver ici:
http://www.nenesse.net/MesBr/index.php
Les couleurs ne sont pas mon gout mais... lol !
Je veux dire par là, pouvoir se servir de sa base html comme d'un catalogue. Toutes recherches acteurs, réalisteurs, affiches, etc...
:cry:
OUI JE SAIS.....
Jamais content...
lol !
Non tout est super et avec le temps, je trouverai...
merci à toi
bonne journée
divxdvd
Post by divxdvd »
Pour infos, je bidouille quelque peu sur le template de dedej...
Dedej airplane.html...
:lol:
Extra comme template...
merci à lui pour de telles lignes de prog !
:grinking:
divxdvd wrote: Je veux dire par là, plus de choix de recherches, par types, catégories, etc...
Ah mais ça ce n'est plus une simple page html exportée sur base d'un template, c'est un site en php qui utilise sans doute soit le catalogue exporté au format xml, soit une base de données créée via l'export sql.
Ce genre de sites on en trouve quelques uns ici sur le forum, mais c'est déjà un peu plus de chipotage pour le mettre en place.
edit: ah bah c'est celui-ci qu'il utilise on dirait : viewtopic.php?t=4500
divxdvd
Post by divxdvd »
ok et pas de souci, j'ai réussi à me trouver un bon template html...
J'ai bidouillé un peu sur son script et ça tourne à fond les ballons !
merci pour ta reponse et bonne fin de week end
Nenesse45
Post by Nenesse45 »
divxdvd wrote:Ok et mille excuses pour le mauvais positionnement de ma demande...
:cry:
OUI JE SAIS.....
Jamais content...
lol !
merci à toi
bonne journée
Je n'utilises plus ce template. Je passe désormais par Wordpress et Filmotech.
divxdvd
Post by divxdvd »
:grinking:
ok et merci pour l'info !
Moi, je reste avec AMC car je le trouve très bien par ses multiples choix...
bonne journée à toi
