Option "Export selected movies" always disable
Sebastien
Post by Sebastien »
I need some help. I want to export movies that i selected
into a html file(s). The export functions works well for my
whole list .
I need to export only some selected movies. And there is an
option on the export windows. But it s always disable. I cannot
click on it.
How to active that option in order to check or uncheck that ?
Seb.
Tips: I m going to use these files with a DVD launcher for Html.
Actually this option is an old thing that I should have replaced by a "selected movies list" like in the Print or Scripting windows.
This option is available only if you enabled Checkboxes in Tools -> Preferences -> Movie list. It allows to export only movies that have their checkbox checked.
Super, Thanks a lot.
