[29.4.2010] Pocket AMC Reader v0.31 released
elman
Post by elman »
Hi folks,
new version of Pocket AMC Reader is now available.
This application will allow you to read catalogs created by Ant Movie Catalog on your Pocket PC. It will read XML catalog and import it into it's own database which is done for performance reasons. On each start the application will check size of XML file and when it changes, database is updated. Depending on size of your catalog, it might take up to 1 minute to import all movies and subsequently up to 15 seconds to start up.
What's new:
29.4.10 Version 0.31
  • - FIXED "Images" renamed to "Pictures" to be consistent with AMC
    - ADDED Program will start even if XML is not present using cached data
    - ADDED Simple finger scrolling in details form. Finger scrolling in movie list is not available at the moment.
    - ADDED All settings can be now changed from within the application
Requirements:
  • - Windows Mobile 6.x
    - .NET Compact Framework 3.5
    - WVGA display (but should work on VGA as well)
    - AMC database saved as XML
    - Images saved with relative links (not necessary, but otherwise you won't see images)
    - Application will take approximately as much disk space as is the size of XML file
Installation:
Cab installer is not available at the moment, so you will have to configure it manually. The application will not write anything to registry.
  • 1. Connect your phone to PC in Active Sync mode
    2. Copy your catalog in XML format and pictures anywhere you like (I
    recommend Storage Card)
    3. Download ZIP file and unpack it to your hard drive
    4. Copy whole folder "Pocket AMC Reader" to phone to \Program Files\
    5. Optionally create shortcut to start menu
    6. Run application
    7. Go to Settings and select your XML catalog
    8. Save, restart the application and enjoy :)
Upgrade:
Just overwrite files on your phone. If you wish to keep the database, don't overwrite "Pocket AMC Reader.db3"
Settings:
Catalog:
Path to XML catalog
Auto Search:
checked = When typing in search input, movies are filtered on the fly.
unchecked = You have to click on "Go" to filter movies.
Auto Search Delay (milliseconds):
If Auto Search is on, search is delayed by this amount of milliseconds allowing you to type words without having to wait for search results on each letter typed.
Remember Tab in Details:
checked = If viewing next movie details, last used tab is remembered.
unchecked = If viewing next movie details, always first tab is selected.
Decimal Ratings:
checked = Ratings are displayed with decimal, e.g. 5.4 .
unchecked = Ratings are integers, e.g. 5 .
Multiple Covers:
checked = Program can loop via multiple covers for one movie. If you have defined in XML image "Movie.jpg", programs scans for images "Movie_B.jpg", "Movie_C.jpg" etc. and displays them. This is workaround until AMC will support multiple pictures and for now is probably useful only for me.
unchecked = Only picture defined in XML is displayed.
Known bugs:
  • - Since Windows Mobile doesn't support XML encoding iso-8859-1, I had to use different one and that means import will break some non English characters
    - Text in fields can be truncated due to bug in AutoResize class. Will look into that later.
Screenshots:
Download:
Current version: http://rapidshare.com/files/1337348989/ ... 0v0.31.zip
Enjoy :)
Eddie
Post by Eddie »
Looks nice. Well done!
JCSullivan
Re: [28.1.2010] Pocket AMC Reader soon to be released
Post by JCSullivan »
elman wrote:Hi folks,
just wanted to let you know that I have started work on Pocket AMC Reader and will be releasing it for public soon. It won't be final version, but it's fairly stable and useful.
Requirements will be:
- .NET CF 3.5
No WM2003 :cry:
elman
Post by elman »
- .NET CF 3.5
No WM2003 :cry:
Sorry, WM2003 is quite old :)
powercat1
Alternative Place To Download?
Post by powercat1 »
I am very interested in this application for PPC. However, I don't have a premium account with Rapidshare and really don't want to create one just to get this application. Is there an alternate way to download it or get it via zip file in email?
Any help you might provide would be greatly appreciated.
You can download for free, just click "free" and wait few seconds.
I'll host it on my server once I'll have downloaded it.
powercat1
Thank You
Post by powercat1 »
I tried the free button on rapidshare and got a message that due to server activity, they weren't allowing free downloads. Thank you for providing the link. I have the zip file and am looking very forward to trying this out.
Thanks again!!!
porzviez
Post by porzviez »
Pocket AMC Reader v0.31 download is not available and Pocket AMC Reader v0.30 doesn't work on my HTC HD2 with WM 6.5. I Would like to try v0.31.
Is there another download?
Thank You
elman
Post by elman »
porzviez wrote:Pocket AMC Reader v0.31 download is not available and Pocket AMC Reader v0.30 doesn't work on my HTC HD2 with WM 6.5. I Would like to try v0.31.
Thank You
Hi, check your pm for download link. Anyways, I owned HTC Diamond 2 with WM 6.5, so it should work for you. You have the same screen resolution as well as same CPU. Be sure to install .NET Compact Framework 3.5 if you haven't done so. If app still doesn't work, post your error message and I will try to help. However I no longer have Visual Studio, so I won't be able to fix anything.
Elman
If you wish I can host the latest version on my server like I did for the previous one
porzviez
Post by porzviez »
Thank you elman, but i think i am to stupid to find it under your link.
I have installed .NET Compact Framework 3.7. The Program doesn't start and the error message with v0.30. is:" Error opening AMC database. Check your settings and restart application."
I changed the settings in Pocket AMC Reader.Settings.xml with XLM Notepad, but after that this the error message is: "The database file is locked".
But it isn't locked.
Thank you very much for your help.
Hallo antp, that would be very kind.
elman
Post by elman »
porzviez, try it and let me know if it works. With version 0.31 there is no need to directly edit Pocket AMC Reader.Settings.xml. You can do that from within the application.
If it still doesn't work, I suspect it might be because of incompatibility between .NET Compact 3.7 and SQLite. You can try:
- Replace SQLite library. Delete files SQLite.Interop.065.DLL and System.Data.SQLite.dll from Pocket AMC Reader, download http://sourceforge.net/projects/sqlite- ... p/download and copy files bin\CompactFramework\SQLite.Interop.066.DLL and bin\CompactFramework\System.Data.SQLite.dll to Pocket AMC Reader folder (just files, do not create subfolders)
or
- Uninstall .NET Compact Framework 3.7 and install .NET Compact Framework 3.5
porzviez
Post by porzviez »
First, thank you very much for your help.
I have got the same problems with version 0.31. I tried to delete Net Compact 3.7, but after a new start during the installation of 3.5 my phone told me, that it is still there, so i can't install 3.5.
I changed the 2 dll's like you told me, but it doesn't work:
Fehler
Pocket AMC Reader.exe
TypeLoadException
Datei- oder Assemblyname
System.Data.SQLite, Version=1.0.65.0,
Culture=neutral,
PublickeyToken=1FDB50B1B62B4C84
bzw. eine Abhängigkeit davon wurde nicht gefunden (could not be find).
I will change Net Compact the next time i have do to a cold start, i hope it is not tomorrow, it'S SO MUCH WORK:
In meantime, i can see all my DVD's as AMC.xls on my phone, But without pictures
elman
Post by elman »
porzviez wrote: Fehler
TypeLoadException
Culture=neutral,
Well, basically it says that my app needs older version of SQLite database, so replacing files won't work.
Try that .NET downgrade as you mentioned.
