In Windows 7 there are no scroll-bars in the "Loans" dialog window.
However the app works fine on Windows XP.
In Win-7 there are no scroll-bars in "Loans" dialo
galex9
galex9
Yes, enabling Enhanced Scrollbars helps, the scrollbars appear.bad4u wrote:Maybe try changing Tools -> Preferences -> Movie List -> Enhanced Scrollbars option just to see if it makes a difference.
However with this option window has to be resized in order for scrollbars to appear and to unfreeze pane borders.
