[REQ] Error in function Fulltrim?
Dear Friends,
some time ago viewtopic.php?t=4139&postdays=0&postord ... m&start=20 I saw that, in my opinion, there was an error in Function FullTrim of StringUtils1 as the function some times truncated the last good letter in a word.
NOw, writing the update of the 35mm.it script I falled in the same error and I constructed a function a little bit different from your 'fulltrim' (see 'here is the difference' in the script).
Here you are an example:
Authors=Fulvio53s03
Title=try Full Trim
Description=
Site=
Language=?
Version=1.0
Requires=3.5
Comments=
License=GPL
GetInfo=0
program TryFullTrim;
  StringUtils1;
  TempField, MytrimField, FulltrimField: string;
  ResultPath: string;
function MyTrim(Value: string):string;
  ExitLoop: Boolean;
  Result := '';
  ExitLoop := False;
    case copy(Value, 1, 1) of
      ' ', #9, #10, #13:    Value := copy(Value, 2, Length(Value)-1);
      ExitLoop := True;
  until ExitLoop;
  ExitLoop := False;
    case copy(Value, Length(Value), 1) of
      ' ', #9, #10, #13:    Value := copy(Value, 1, Length(Value)-1); // here is the difference
      ExitLoop := True;
  until ExitLoop;
  Result := Value;
 tempfield := #9 + ' ' + #9 + ' ' +#9 + ' ' + 'America' + #9 + ' ' +#9;
 MytrimField := MyTrim(TempField);
 FulltrimField := FullTrim(TempField);
 Showmessage ('***' + MytrimField + '***' + FulltrimField + '***');
Would you try to execute and tell me if my function is always right or if there is a Bug?
Thanks in advance
:wink:
Hmm.. this is identical with the FullTrim function from StringUtils1.pas. Maybe you used an older version prior v6 of this file ? Last update of this file was in february (it was updated because of Cp1252ToASCII function, I guess). You can check your file version on constant "StringUtils1_Version = 6;" and you can use this constant in your script to check if user has latest version of StringUtils1 installed, so that you can be sure your script runs correct.
http://update.antp.be/amc/scripts/StringUtils1.pas
Thanks Bad4U, You are right (as usual).
I tried to insert the check of Stingutils1 in my script but with bad results. Would you give me an example, Please?
In addition: I saw in new StringUtils1 a function called Cp1252ToASCII and I hoped it could resolve my problems of accented letters (see viewtopic.php?t=4464 but it isn't so.
Would you (or Antp) help me? ... any suggestion? :D
Have a good Sunday You all.
Ciao. :grinking:
You can find an example for checking StringUtils1 version and using Cp1252ToASCII function on latest IMDB script:
function ConvertToASCII(AText: string): string;
  Result := AText;
  if GetOption('ConvertToASCII') = 1 then
    if StringUtils1_Version > 5 then
      Result := Cp1252ToASCII(AText)
      ShowMessage('The "ConvertToASCII" option requires a newer version of StringUtils1.pas (at least version 6).' + #13#10 + 'Run the "Update Scripts" script to get it.');
Copy this function to your script and simply use ConvertToASCII(Value) to call it from your code. And/or you can check StringUtils_Version on the beginning of your script if you want make sure it has latest FullTrim version included (there's an example on IMDB script for that, too, simply replace "Checkversion(x,x,x)" with "StringUtils_Version > 5").
About the problem with apostrophes, it should be ok the way you use
UrlEncode(MovieName)
If it doesn't work for you, try to replace with
UrlEncode(UTF8Encode(MovieName))
or with
StringReplace(UrlEncode(UTF8Encode(MovieName)),'''',' ')
Sorry, I do not have time to do some tests at the moment.
Allright about check version of StringUtils1 :grinking:
The solutions proposed about accented letters are not OK, unfortunately :cry:
No other Ideas?
Thanks. :shaking:
I get lots of 404 messages with any title that I type, what is that accent problem?
@Antp
Thanks.
I think you are getting errors 404 as You are using the old script 35mm.it.
If you try with my new script viewtopic.php?t=4464 you will see that accented vocals are not translated (but in the source of the html page they are non showed)... I tried in a lot of ways to avoid the problem but I don't find solutions... :cry:
Have a good evening.
I thought that I used that update but I have put it in a wrong folder :lol:
The "problem" is that the page is in UTF8, if I understood well you get Luis Buñuel where you want to have Luis Buñuel?
So you have to use UTF8Decode in each SetField which could contain accents.
e.g. : SetField(fieldDirector, UTF8Decode(TempField));
Alternatively (maybe easier, as you have to insert only at one or two point of the script) is to do the UTF8Decode on the whole page before processing it.
What can I say? Astonished!
Now it's all Ok (till next doubt :wow:)
Bye.
