[REL ITA] 35mm.it
[REL ITA] 35mm.it
Hi, my friends.
I wrote a new version of the script and now it's OK but.... I'm not able to translate some special characters (they look accents).
Use the script with the translated title 'L'angelo sterminatore' and you will understand what I mean. If someone could help me, the script would be 'almost perfect'.
:wink:
Ho scritto una nuova versione dello script ed ora funziona. Unico neo (mi sembra), non riesco a convertire dei caratteri speciali che compaiono nei campi visualizzati (vedi il film 'L'angelo sterminatore' e capirete cosa intendo).
Se qualcuno riuscissa a risolvere il problema, lo script sarebbe 'quasi perfetto'.
Authors=fUlvio53s03
Title=35mm.it
Description=Get movie info from 35mm.it
Site=http://www.35mm.it
Language=IT
Version=10.10.2009
Requires=3.5.0
Comments=|
License=
program New35mm;
  Stringutils7552;
  UrlBase = 'http://www.35mm.it';     //
  QueryBase = UrlBase + '/search/?string=';
  QueryFilm = UrlBase + '/film/scheda/top/scheda.jsp?idFilm=';
  QueryCast = UrlBase + '/film/scheda/bottom/cast.jsp?idFilm=';
  QueryCover = UrlBase + '/film/scheda/bottom/homevideo.jsp?idFilm=';
  QueryMovie = UrlBase + '/';
  QueryCmnts = UrlBase + '/film/scheda/bottom/recensioni.jsp?idFilm=';
  QueryTrama = UrlBase + '/film/scheda/popup/trama.jsp?idFilm=';
  QueryFinale = UrlBase + '/film/scheda/popup/finale.jsp?idFilm=';
  MovieUrl, FilmUrl, CoverUrl: string;
  MovieName, OriginalStr, TranslatedStr, PageStr:  string;
  UsePage, OldField, NewField: string;
  EndChar, StartChar: string;
  LgthUsePage, LengthRaw, StartPos, EndPos: integer;
// DELETE DOTS AT END OF STRIG
// IN:  Text      (string)
// OUT: RemoveDot (string)
function RemoveDot (Text: string) : string;
  intLenght : integer;
    intLenght := Length(Text);
    if copy(Text,intLenght -1 ,1) = '.' then
        delete(Text, intLenght -1 ,1);
  until (copy(Text,intLenght -1,1) <> '.');
  result := Text;
End;
function cambiaAccenti(str1: string) :string;
	str1 := StringReplace(str1, 'Ã', 'a' + #39);
	str1 := StringReplace(str1, #195, 'u');
	str1 := StringReplace(str1, #226, 'o' + #39);
	str1 := StringReplace(str1, #227, 'o' + #39);
	str1 := StringReplace(str1, #228, 'o' + #39);
	str1 := StringReplace(str1, #229, 'o' + #39);
	result := str1;
function MyTrim(Value: string):string;
  ExitLoop: Boolean;
  NewField, OldField: String;
  OldLgthValue, NewLgthValue: integer;
    NewField := ' ';
    OldField := #9;
    value := StringReplace(Value, OldField, NewField);
    OldField := #10;
    OldField := #13;
    OldField := '  ';
    ExitLoop := False;
    OldLgthValue := length(Value);
      NewLgthValue := length(Value);
    if  OldLgthValue = NewLgthValue then
        ExitLoop := True
        OldLgthValue := NewLgthValue;
    until ExitLoop;
  Result := '';
  ExitLoop := False;
    case copy(Value, 1, 1) of
      ' ', #9, #10, #13:    Value := copy(Value, 2, Length(Value)-1);
      ExitLoop := True;
  until ExitLoop;
  ExitLoop := False;
    case copy(Value, Length(Value), 1) of
      ' ', #9, #10, #13:    Value := copy(Value, 1, Length(Value)-1);
      ExitLoop := True;
  until ExitLoop;
  HTMLRemoveTags(Value);
  Result := Value;
// ANALYZE MOVIE DATA PAGE
// IN:  none
// OUT: set Ant fields
procedure AnalyzeMoviePage;
  i, h, m: integer;
  Duration, Description, Cast, TempStr, TempImg, hh, mm: string;
  TempField, Prova: string;
  // Get packed title main page
  PageStr := Getpage(FilmUrl);
//  PageStr := RemoveExtraChars(FilmUrl);
  // Get film image
  tempImg := textBetween(PageStr, '<div id="cover">', '</div>');
  tempImg := textBetween(tempImg, '<a href="', '" rel=');
  tempImg := Urlbase + FullTrim(tempImg);
  getPicture(TempImg);
  // Translated Title field
  Tempfield :=  textBetween(PageStr, '<li><span>Titolo:</span>', '</li>');
  TempField := Mytrim(TempField);
  SetField(fieldTranslatedTitle, TempField);
  // Original Title field
  TempField := textBetween(PageStr, '<li><span>Titolo originale:</span>', '</li>');
  SetField(fieldOriginalTitle, TempField);
  // Country field
  TempField := textBetween(PageStr, '<span>Nazione:</span>', '</li>');
  TempField := MyTrim(TempField);
  SetField(fieldCountry, TempField);
  // Category Field
  TempField := textBetween(PageStr, '<span>Genere:</span>', '</li>');
  TempField := TextBetween(tempField, '">', '<');
  SetField(fieldCategory, TempField);
  // Duration field
  TempField := textBetween(PageStr, '<span>Durata:</span>','min</li>');
  SetField(fieldLength, tempField);
  // Director Field   <span>Regia:</span>
  TempField := textBetween(PageStr, '<span>Regia:</span>','</li>');
  SetField(fieldDirector, TempField);
  // YearField
  TempField := textBetween(PageStr, '<span>Anno di produzione:</span>','</li>');
  SetField(fieldYear, TempField);
  // Producer Field
  TempField := textBetween(PageStr, '<span>Distribuzione:</span>','</li>');
  SetField(fieldProducer, TempField);
  // Movie URL field
  SetField(fieldURL, MovieUrl);
  // Description Field
  TempField := textBetween(PageStr, '<div class="description">','</div>');
  TempField := cambiaAccenti(TempField);
  SetField(fieldDescription, TempField);
   // Comments Field
  TempField := textBetween(PageStr, '<span>Distribuzione:</span>','</div>');
  TempField := textBetween(TempField, 'title="','">');
  TempField := 'Distribuzione: ' + TempField;
  SetField(fieldComments, TempField);
  // Actors Field
  StartChar := '<div id="mod_castcrew_tabs" style="position:relative;">';
  EndChar  := '<div class="mod_castcrew_tab" id="mod_castcrew_tab_crew"';
  Usepage := Textbetween(Pagestr, StartChar, EndChar);                 // estraggo tutta la stringa degli attori
  lengthRaw := length(Usepage);
  StartChar :=  '<div class="box_rightcol_list_user_right">';
  StartPos := Pos(StartChar, Usepage);
  Delete(UsePage, 1, StartPos - 1);
  EndChar :=  'height="50px" />';
  UsePage := Usepage + EndChar;                        // evito forzatamente LengthRaw < 100 per l'ultimo interprete
  TempField := StartChar + TextBetween(UsePage, StartChar, EndChar) + EndChar;
  LengthRaw := length(TempField);
  StartChar :=  'title="';
  EndChar :=  '</h4>';
  Cast := '';
//      UsePage  := PageStr;
  StartPos := pos(StartChar, UsePage);
     StartChar := '>';
     EndChar := '</a>';
     TempField := TextBetween(TempField, StartChar, EndChar);
     Cast := Cast + TempField + '; ';
     Delete(UsePage, 1, LengthRaw);
     LgthUsePage := length(UsePage);
     LengthRaw := Length(Tempfield);
     EndChar :=  '</h4>';
  until(LengthRaw < 100);
  Cast := copy(Cast, 1, length(Cast) - 2);      // tolgo ultimo ;
  SetField(fieldActors, Cast);
// IN:  OneFilm flag (bool)
// OUT: one page ID  (string)
  TempIdFilm, TempTitle: string;
  LengthFilm: integer;
  if OneFilm then
    begin        // questa routine est OK
      StartPos := pos('<a class="title" href="', PageStr);
      UsePage  := copy(PageStr, StartPos + 23, length(PageStr) - Startpos);
      EndPos := pos('" title="', UsePage);
      if StartPos > 0 then
          startPos := 0;
          TempIdFilm := copy(UsePage, StartPos, EndPos - Startpos - 1);
          result := TempIdFilm;
        StartChar :=  '<a class="title" href="';
        EndChar :=  '<div class="pagination"></div>';
        UsePage := StartChar + TextBetween(PageStr, StartChar, EndChar) + EndChar;
//        UsePage  := copy(UsePage, StartPos + 23, length(UsePage) - Startpos);
        EndChar := '" title="';
            TempIdFilm := TextBetween(UsePage, Startchar, EndChar);
            LengthFilm := length(StartChar) + length(TempIdFilm) + length(EndChar);
            Delete(UsePage, 1, LengthFilm);
            LengthRaw := length(UsePage);
            StartChar := '">';
            EndChar := '</a>';
            TempTitle := TextBetween(UsePage, Startchar, EndChar);
            PickTreeAdd(TempTitle, TempIdFilm);
            LengthFilm := length(StartChar) + length(TempTitle) + length(EndChar);
            Delete(UsePage, 1, lengthFilm);
      until(StartPos = 0);
      result := '';
// IN:  page Url (string)
// OUT: none
procedure AnalyzeSearchPage(Url: string);
   FilmId: string;
  PageStr := getpage(Url);
//  PageStr := RemoveExtraChars(Url);
  if pos('Nessun film trovato.', PageStr) > 0 then
  else if pos('Si è verificato un errore',PageStr) > 0 then
    ShowMessage('Server not available, try later / Server non disponibile, prova più tardi')
      if pos('Risultato della ricerca per:', PageStr) = 0 then
        MovieUrl := PopulatePickTree(true)   // One title found
          PopulatePickTree(false);           // More titles found..
      FilmId := MovieUrl;                    // get film id from movie url
      FilmUrl := MovieUrl;
      CoverUrl := QueryCover + FilmId;
      AnalyzeMoviePage;
// MAIN:
// IN:  none
// OUT: none
  if CheckVersion(3,5,0) then
      if (TranslatedStr <> '') then
        MovieName := TranslatedStr
        MovieName := OriginalStr;
      if (Input('35mm.it - ', 'Enter the title of the movie / Inserire titolo del film:', MovieName)) then
          MovieUrl := QueryBase + UrlEncode(MovieName) + '&where=1';
          AnalyzeSearchPage(MovieUrl);
:wink:
With Antp and bad4U's help, i'm proud to say that the script now is almost perfect. Make me know if you find errors.
bye.
Con l'aiuto di Antp e bad4U ora lo script è a posto. fatemi sapere se ancora qualcosa non va.
ciao
Authors=fulvio53s03
Title=35mm.it
Language=IT
Version=13.10.2009
Requires=3.5.0
Comments=|
License=
program New35mm;
  Stringutils1;
  MovieUrl, FilmUrl: string;
  ExitLoop: Boolean;
    NewField := ' ';
    OldField := #9;
    OldField := #10;
    OldField := #13;
    OldField := '  ';
    ExitLoop := False;
        ExitLoop := True
    until ExitLoop;
  Result := '';
  Result := Value;
// IN:  none
  i, h, m: integer;
  LgthImgName: integer;
  PageStr := UTF8Decode(PageStr);
  // Get film image
  tempImg := textBetween(tempImg, '<a href="', '" rel=');                     // <img src="
  LgthImgName := Length(FullTrim(tempImg));
  if LgthImgName > 0 then
     else begin
        tempImg := textBetween(PageStr, '<div class="cover_white">', '</div>');
        tempImg := textBetween(tempImg, '<img src="', '" alt="cover"');                     // <img src="
  TempField := FullTrim(TempField);
  // Country field
  // Category Field
  // Duration field
  // YearField
  // Producer Field
  // Movie URL field
   // Comments Field
  if Length(TempField) > 0 then
  // Actors Field
  EndChar :=  '</h4>';
  Cast := '';
     StartChar := '>';
     EndChar := '</a>';
     EndChar :=  '</h4>';
  if OneFilm then
          startPos := 0;
            StartChar := '">';
            EndChar := '</a>';
      result := '';
// OUT: none
   FilmId: string;
      AnalyzeMoviePage;
// MAIN:
// IN:  none
// OUT: none
  if (CheckVersion(3,5,0)) and (StringUtils1_Version > 5) then
      if (Input('35mm.it - ' + Moviename, 'Enter the title of the movie / Inserire titolo del film:', MovieName)) then
    ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 3.5.0) and StringUtils1 version 6');
:clapping:
simpic
Post by simpic »
Provato ora e funziona!
Solo un dettaglio: se cerco con il titolo per intero esce una finestra bianca in cui non mi fa selezionare nessun film. Se invece scrivo 1-2 parole del titolo mi esce la finestra con la lista dei film tra cui scegliere...
Succede solo a me?
simpic wrote:...se cerco con il titolo per intero...?
Purtroppo succede a tutti... la ricerca è sensibile anche ai blank, per non parlare del fatto che la pagina è codificata in UTF8 e quindi con un sacco di caratteri "sporchi"....
ciao.
otreux
Post by otreux »
Grazie funziona benissimo :D
Thank's it works perfectly
