importing movie files from directory possible?
tom1
Post by tom1 »
hi all,
I have a drive (HDD) with many movies that are stored as .mp4 files (H.264, encoded with x.264). Each video file has the movie title as filename.
is there an easy way to import all videofiles form that directory and automatically set meta information like file size, format and length of the movie?
is it possible to import information from IMDB without confirming each and every title (which takes a lot of time)?
thanks in advance.
regards,
tom
Please read viewtopic.php?t=229
There are few tools mentioned/linked on this topic that should do this job, but I never did test any of these myself. Be sure to read the topic to the end.
