Hi Antoine,
I have thumbled around with my personal language file and rearranged my fields a bit.
When I now try to set the "default movie values" through Tools-Preferences the fields available are not all visible.
The last column with fields is out of boundaries. Only the lables are shown, i can't reach the textboxes because they are not visible. the scrollbar is at his end.
I will send you a screenshot later when i'm able to do so.
Layout problem witinh "Default Movie Values" Dialo
biker72
biker72
ok, if it's no bug, it must be by design
To clarify things a bit:
I rearranged the fields. The result is that the total width of the screen is smaller than the original setup. (except for the floating pic window)
The original "edit default values"-window compresses the field-width somewhat so that it fits the window. In my instance there appear some scrollbars. But at the end of the scrollbar it stops at the labels of the last column and the textboxes are not shown.
I send you some screenprints comparing the original with my new setup.
Thanks again.
Thanks again.
biker72
