Is there a Script tutorial?
dolphinBoy
I'd like to write a script, don't know where to start!
Re: Is there a Script tutorial?
There isn't really a tutorial.
If you don't know Delphi/Pascal, it can be useful to check some basic tutorial about that, as the script engines uses a similar syntax.
Then I'd suggest checking existing scripts, and the "Technical Info" section of the Help file that comes with AMC.
dolphinBoy
Thanks, I used to know Pascal.... back in the 1980s!
No Joke! I used This one for my "A" levels https://en.wikipedia.org/wiki/Apple_Pascal
I'm not complaining about that you understand, just that my skills are somewhat rusty to say the least!
I can "monkey-see monkey-do" but that's about my limit.
Fancy writing a script please? The REQ is over in the scripts forum!
Why don't you try to understand a script AMC you are using to extract movie's informations?
I think it could be a good way to understand how writing a script.
dolphinBoy
Working on it...
Well, you are on the right way!
Let's know how your work proceeds....
