Media Label Field Suggestion
Totototo
Post by Totototo »
Been using the program for a while now, its great.
I´m having a problem with the sorting by media label field, to be more specific, i have compilations of movies and i use this field to store the label of the compilation, some are numbers, and others are plain strings, the thing is that this field doesnt recognize if its a number or a string and when i sort or group the movies by media label i get the numbers sorted as if they where strings.
For instance, my first compilations are shown like this:
1, 10, 100 , 101, 102, ... ,119,12,120, etc...
Maybe im asking too much but if the sorting could be made separately first for integers and then for the strings, it would be very usefull, at least for me, ;).
Oh, and tanks a lot for this great tool!
You can simply put a "0" in front of lower numbers :whistle:
But indeed I should sort numbers as numbers in that field, as it is often used for such contents.
Totototo
Post by Totototo »
Yeah, that solves my problem, the thing is that i would have to add the extra 0's in each movie, and that could be really anoying (800 titles...).
But then again, i think i could try to write a script to do that or to export everything to .xsl, change it and import it back.
Anyway, thanks for the tip.
A script is easy to make. e.g. to make 4-digit numbers:
program NewScript;
  s: string;
  s := GetField(fieldMedia);
  while Length(s) < 4 do
    s := '0' + s;
  SetField(fieldMedia);
inigoth
Post by inigoth »
Ive been using this script since last year but recently i update AMC version and now this script no longer works.
Error says "comma expected line 8"
line 8 its: SetField(fieldMedia);
any solution?
ty
Edit:
Im using:
MovieCatalog.exe : versión 3.5.1.2 (creado el 01/02/2009 18:15:52)
AMCExchange.dll : versión 1.1.0.1 (creado el 22/09/2007 11:47:56)
AMCReport.exe : versión 1.0.2.2 (creado el 15/01/2005 16:13:58)
MediaInfo.dll : versión 0.7.10 (creado el 30/01/2009 10:19:42)
The variable is missing, it must be
SetField(fieldMedia,s);
inigoth
Post by inigoth »
Yes, now it works!!
i had to hange last line too
end; -> end.
Thanks a lot!!
