advanced sort options fields not visible
don
i am unable to see any of the fields in the print advanced sort options screen. I have a blank screen except for the arrow in the middle. I have 2 computers both running xp pro with all updates and sp2. It works ok on one computer, but not the other. any suggestions?
don
don
version 3.51. I tried reinstall. no go. video card is a geforce 6200 dual display. language selection works great. Only problem is with field variables. also have the same problem with the properties of imdb script. I am unable to view the fields there as well. that's where I actually discovered the problem. I was unable to selet and change the mpaa rating option.
the only thing I can figure is a dll or ocx version issue. I have alpha five version 8 on this computer (eveything works fine with programs created). the other machine has visual foxpro 9 on it.
don
don
