Create
pty99
Create
Post by pty99 »
Hello
Thanks for this great software
I'd like to know if it's possible create a report of movies stored in disk folder or dvd without add this movies to amc catalog.
Re: Create
pty99 wrote:I'd like to know if it's possible create a report of movies stored in disk folder or dvd without add this movies to amc catalog.
What kind of "report" ?
See viewtopic.php?p=17829#17829
or more specifically viewtopic.php?t=3474
You can import the resulting CSV file in Excel.
pty99
Post by pty99 »
I need a basic report to use when i have to catalog tv series. I don't want to create an entry for every single episode but i want add a single item in amc catalog and put in the description field some basic informations as file size, codec, bitrate, etc...
AVIList it's what i was looking for
