Big Files Error in dimension, length, Video bitrate
zzz_siberia_zzz
Post by zzz_siberia_zzz »
when importing big avi files [4+GB] ant made an error getting information from the file. it reports incorrect file size [sometimes negative, sometimes very small 350 or so], incorrect video bitrate [very big numbers, usually above 10.000]and incorrect length [always under an hour].
Audio codec & bitrate, video codec, resolution and frame rate are identified correctly.
I tryed about 10 files ranging from 3,7 to 4,4GB, encoded with xvid, h.264, wmv3.
bye
Siberia
File size was limited to 2 GB, it is fixed for next version, cf viewtopic.php?t=3325
Other info depend on which engine you use. If you use MediaInfo it may be fixed in that new version as lots of things were improved.
zzz_siberia_zzz
the new beta version fixes the file size reporting, but not the video bitrate nor the time length of the avi.
I've update both the program and the mediainfo but not tried the mixed combination [old prog + new mediainfo].
I'll wait for new releases to test.
thanks for the great work.
bye
Siberia
PS.
It isn't a real problem, the number of hdtv files I own is not so high and i can insert easily the gspot data myself.
Information
MovieCatalog.exe : version 3.5.1.0 (11/11/2006 18.05.20)
AMCExchange.dll : version 1.0.1.8 (01/11/2006 11.33.02)
AMCReport.exe : version 1.0.2.2 (15/01/2005 16.13.58)
MediaInfo.dll : version 0.7.3.1 (30/07/2006 23.06.50)
old prog will not work with new media info, and anyway it won't solve the problem ;)
In Tools -> Prefs -> Media file import, is the option "use internal engine" unchecked? if yes, then it means that the bug comes from MediaInfo, I think.
zzz_siberia_zzz
well, i was using the internal renderer, with the mediainfo enabled file size and movie length are ok :grinking: . video bitrate is about doubled [2,15-2,3X] but decrease at every post. we are very near ;)
I think that is a mediainfo matter now.
thanks again
Siberia
