IMDB "No movie found" error
motkun
Post by motkun »
Hi;
Since yesterday, while trying to get the information of the movies with IMDB script, a "no movie found" warning appears constantly. When I first run ANT, it finds 1 or 2 movies normally and takes their data, but then it starts giving errors again. Thinking it might be a problem with the cache memory, I cleared the cache but the situation didn't change. Would you please help me?
Thanks in advance.
Re: "No movie found" error
IMDb changed something on their site.
I'll have to fix the script for that in the next days (or someone else, if one can do it before).
Otherwise there was a newer experimental version of the script in progress: https://forum.antp.be/phpbb3/viewtopic.php?t=20711
That one seems to still work, maybe I'll use that one as replacement, but for that there is a few things in it (default settings that may not be ideal for all users).
If you prefer to wait for an easy-to-update version you can just wait a few days.
motkun
Post by motkun »
Thank you, I'll try the experimental one firstly. If it is unsatisfactory waiting will be the only option. :)
motkun
Post by motkun »
I noticed that if I select a large number of movies and run the script in bulk, if it can import the first one, it can import the rest without any problems. As far as I understand, there is a connection problem to imdb. Maybe imdb has developed a way to prevent getting data of large number of movies in a short time.
When you mention import in bulk, I assume that these entries already have an URL stored?
Indeed it seems that it is only the title search which is broken.
When pasting a IMDb URL instead of entering a title when prompted, the old script still works.
Actually the search seems to work too... Maybe it was just a temporary problem on IMDb?
Or do you still encounter issues?
motkun
Post by motkun »
My database was on GCStar. Unfortunately, I was only able to transfer the movie titles and their years due to many errors that occurred during the transfer to Ant. I have a long list of movies now, and I'm trying to complete the data again. That's why I said bulk. If the script can be connec, it works for me too, but after a few movies it stops connecting and give the error that I mentioned. After a few minutes it connects again and take a few movies data.
I'm on a pentium notebook with a 4 gb RAM and windows 10. Maybe the problem is my underpowered computer.
It depends on the error. When you get errors 403, forbidden, etc. that's on IMDb-side. Either they have issues, or they are limiting the number of requests on purpose.
Now it just shows me a message "no movie found", that's the script that should be fixed because in the end they changed something.
I did a small change which seems to work right now, but it may break again if they change other things.
You can get the latest version of the script by running the "Update scripts" script at the top of the list.
New version of IMDb is 4.017
motkun
Post by motkun »
Thanks for your efforts dear antp, but the problem persists in another way with the new script. Now "Titles search results" is empty in the Movie selection window, and after a few minutes, the script can run normally for 1 or 2 try.
To test if the problem is with my small notebook, I tried installing ANT on a desktop computer with an i7 processor and more memory, but it has the same problem.
oobaka67
Post by oobaka67 »
antp wrote: 2022-10-01 07:38:11 Otherwise there was a newer experimental version of the script in progress: https://forum.antp.be/phpbb3/viewtopic.php?t=20711
Doesn't work for me every time. Tried several movies. Problem comes and goes.
The original script worked sometimes but not every time. Same with the newer script.
I didn't like the way the new script was working so I completely reinstalled the program
with all its original scripts and, so far, it's been working as it should.
motkun
Post by motkun »
it works just fine now, thank you
bhilam
Post by bhilam »
I have updated the IMDB script (it is still a work in progress) to get it to work in most scenarios. When I get 404 or no data, I have tried re-running the script which often works fine but there are also times where I am just unable to fetch the data and ended up passing URL so that will need to be looked at. I am sure there is probably better way to fix the issue as I've only "hacked" my way thru the script.
Note: Below script does contain some of the modifications I made for my personal use (certification or MPAA rating data and couple of minor tweaks) so if you do not want any of that then just
copy and paste code from lines 97 to 158 starting from line
program IMDB;
//  Debug,
  StringUtils1, StringUtils7552;
  PopularTitleSearchURL =  'https://www.imdb.com/find?s=tt&q=';
  FullTitleSearchURL = 'https://www.imdb.com/find?s=tt&exact=true&q=';
  EpisodeTitleSearchURL = 'https://www.imdb.com/find?s=ep&q=';
  MovieURL: string;
  MovieNumber: string;
  MovieYear: string;
  UpdateFile: TStringList;
function ConvertToASCII(AText: string): string;
  Result := UTF8Decode(AText);
  if Result = '' then
    Result := AText; // in case of a UTF8 decoding error
  if GetOption('ConvertToASCII') = 1 then
    Result := Cp1252ToASCII(Result);
function AKACountry: string;
  UserCountry: string;
  UserCountry := GetParam('UserCountry');
  if UserCountry = 'United States' then
    Result := 'USA'
  else if UserCountry = 'United Kingdom' then
    Result := 'UK'
    Result := UserCountry;
// ***** analyzes IMDB's results page that asks to select a movie from a list *****
  PageText: string;
  Value: string;
  PageText := ConvertToASCII(GetPage(Address));
  if pos('<title>Find - IMDb', PageText) = 0 then
      AnalyzeMoviePage(PageText)
            ShowMessage('No movie found for this search.');
          Exit;
        Value := TextBetween(PageText, '>Titles</h3>', '</section>');
        if Value <> '' then
          PickTreeAdd('Titles search results', '');
          //ShowMessage('Val: ' + Value);
          AddMovieTitles(Value);
          AnalyzeResultsPage(Address);
        if (MovieYear <> '') then
            Value := GetUrlBefore(PageText, '(' + MovieYear + ')', '');
            if Value = '' then
                Value := GetUrlBefore(PageText, '(' + IntToStr(StrToInt(MovieYear, 0) - 1) + ')', '');
                if Value = '' then
                  Value := GetUrlBefore(PageText, '(' + IntToStr(StrToInt(MovieYear, 0) + 1) + ')', '');
            if Value <> '' then
              AnalyzeResultsPage('https://www.imdb.com' + Value);
            Value := TextBetween(PageText, '<td class="primary_photo">', '<img src');
            if Value <> '' then
              AnalyzeResultsPage('https://www.imdb.com' + TextBetween(Value, '<a href="', '"'));
// ***** adds the movie titles found on IMDB's results page *****
  Value: string;
  Year: string;
  AdditionalValue: string;
  Address: string;
  SummaryValue: string;
  Result := False;
//ShowMessage('L1 :' + List);
  //Value := TextBetween(List, '<td class="result_text">', '</td>');
  Value := TextBetween(List, '<a class="ipc-metadata-list-summary-item__t" role="button" tabindex="0" aria-disabled="false" ', '</a>');
//ShowMessage('V1 :' + Value);
  if GetOption('HideAkaTitles') = 1 then
    Value := StringReplace(Value, TextAfter(Value, '<br/>aka'), '')
    Value := StringReplace(Value, 'aka', ' | aka');
    List := RemainingText;
//ShowMessage('L2 :' + List);
  while Value <> '' do
    Address := TextBetween(Value, 'href="/title/tt', '/');
    Address := Address + '/reference';
    Value := TextAfter(Value, '">');
    HTMLRemoveTags(Value);
    HTMLDecode(Value);
//ShowMessage('Add: ' + Address);
    SummaryValue := TextBetween(List, 'ipc-metadata-list-summary-item__li', '</div><div');
//ShowMessage('SV: ' + SummaryValue);
    Year := TextBetween(SummaryValue, '">', '</span></li>');
    HTMLRemoveTags(Year);
    HTMLDecode(Year);
    Value := Value + ' (' + Year + ')';
//ShowMessage('V + AV: ' + Value);
    SummaryValue := RemainingText;
    while SummaryValue <> '' do
          AdditionalValue := TextBetween(SummaryValue, 'ipc-metadata-list-summary-item__li">', '</span></li></ul>');
          if AdditionalValue <> '' then
//ShowMessage('SV Inside: ' + SummaryValue);
            HTMLRemoveTags(AdditionalValue);
            HTMLDecode(AdditionalValue);
            Value := Value + ' | ' + AdditionalValue + ')';
//ShowMessage('V2 + AV: ' + Value);
            break;
    PickTreeAdd(Value, 'https://www.imdb.com/title/tt' + Address);
    Result := True;
//ShowMessage('L3: ' + List);
// ***** analyzes the page containing movie information *****
procedure AnalyzeMoviePage(PageText: string);
  Value, Value2, FullValue, LastValue, originalTitle, certificationValues, LastCertificationValue: string;
  p, Count: Integer;
  MovieNumber := TextBetween(PageText, '<input type="hidden" name="auto" value="legacy/title/tt', '/');
  if MovieNumber = '' then
    MovieNumber := TextBetween(PageText, '<input type="hidden" name="auto" value="legacy/title/tt', '/reference"');
    MovieNumber := TextBetween(PageText, '<link rel="canonical" href="https://www.imdb.com/title/tt', '/');
  if Pos('/reference"', TextBetween(PageText, '<link rel="canonical"', '/>')) = 0 then
    PageText := ConvertToASCII(GetPage('https://www.imdb.com/title/tt' + MovieNumber + '/reference'));
  MovieURL := 'https://www.imdb.com/title/tt' + MovieNumber;
  // URL
  if CanSetField(fieldURL) then
    SetField(fieldURL, MovieURL);
  // OriginalTitle & Year
  if CanSetField(fieldOriginalTitle) or CanSetField(fieldYear) then
    originalTitle := TextBefore(PageText, '(original title)', '</h1>');
    HTMLRemoveTags(originalTitle);
    HTMLDecode(originalTitle);
    originalTitle := RemoveSpaces(originalTitle, true);
    if (originalTitle <> '') and CanSetField(fieldOriginalTitle) then
      SetField(fieldOriginalTitle, FullTrim(originalTitle));
    Value := TextBetween(PageText, '<title>', '</title>');
    p := Pos(' (1', Value);
    if p = 0 then
      p := Pos(' (2', Value);
    if p = 0 then
      p := Pos(' (TV', Value);
    if p > 0 then
      Value2 := Copy(Value, 0, p-1);
      Value := Copy(Value, p+2, Length(Value));
      HTMLDecode(Value2);
      if (originalTitle = '') and CanSetField(fieldOriginalTitle) then
        SetField(fieldOriginalTitle, FullTrim(Value2));
        if Pos('/', Value) > 0 then
          Value := TextBefore(Value, '/', '');
          Value := TextBefore(Value, ')', '');
        if Pos('–', Value2) > 0 then
          Value := TextBefore(Value, '–', '');
        SetField(fieldYear, Value);
    originalTitle := TextBefore(PageText, '(original title)', '</h3>');
    if originalTitle ='' then originalTitle := TextBetween (PageText,'<h3 itemprop="name">','<span class="titlereference-title-year">');
    Value:= TextBetween (Pagetext, '<span class="titlereference-title-year">', '<ul class="ipl-inline-list">');
    Value:= TextBetween (Value, 'url', '</a>)');
    Value:= TextAfter (Value, '>');
  if CanSetField(fieldYear) then SetField(fieldYear, Value);
  // Picture
  if CanSetPicture then
    case GetOption('ImageKind') of
      2:  if not ImportSmallPicture(PageText) then
              ImportPictureNotAvailable(PageText);
      3:  ImportLargePicture(PageText);
      4:  if not ImportMerchandisingPicture then
              if not ImportDvdDetailsPicture then
                ImportSmallPicture(PageText);
      5:  if not ImportDvdDetailsPicture then
      3:  if not ImportLargePicture(PageText) then
  // Director
    Value := TextBetween(PageText, '<h4 name="directors"', '</table>');
    FullValue := '';
    Value2 := TextBetween(Value, '<a href="/name/', '</a>');
    while Value2 <> '' do
      Value2 := TextAfter(Value2, '>');
      if FullValue <> '' then
      FullValue := FullValue + Value2;
    HTMLDecode(FullValue);
    FullValue := RemoveSpaces(FullValue, true);
  // Actors
    if GetOption('AllActors') = 0 then
      FullValue := TextBetween(PageText, ' Stars:', '</li>');
      HTMLRemoveTags(FullValue);
      FullValue := '';
      Value := FullTrim(TextBetween(PageText, '<h4 name="cast"', '</table>'));
      if Value <> '' then
        Count := 0;
        p := StrToInt(GetParam('MaxActors'), 10);
        case GetOption('ActorsLayout') of
          0, 1:
            while Pos('<tr class', Value) > 0 do
              Value2 := TextBetween(Value, '<tr class', '</tr>');
              if Pos('Rest of cast', Value2) > 0 then
                Continue;
              TextBefore(Value2, '</td>', '');
              Value2 := FullTrim(TextBetween(Value2, '<td class="itemprop" itemprop="actor" itemscope itemtype="http://schema.org/Person">', '</td>'));
              HTMLRemoveTags(Value2);
              Value2 := RemoveSpaces(Value2, true);
              if Value2 <> '' then
                Count := Count + 1;
              if (Count = p) and (GetOption('AllActors') = 2) then
          2, 3, 4:
            while Pos('<tr', Value) > 0 do
                Continue;
                Value2 := FullTrim(TextBetween(RemainingText, '<td class="character">', '</td>'));
                  if GetOption('ActorsLayout') = 4 then
                    FullValue := FullValue + ' ... ' + Value2;
                    FullValue := FullValue + ' (as ' + Value2 + ')';
                Count := Count + 1;
          0, 2:
              FullValue := StringReplace(FullValue, #13#10, ', ');
  // Composer
  if CanSetField(fieldComposer) then
    Value := TextBetween(PageText, '<h4 name="composers"', '</table>');
    FullValue := '';
    SetField(fieldComposer, FullValue);
  //Country
    SetField(fieldCountry, ImportList(PageText, GetOption('MultipleValuesCountry'), '<td class="ipl-zebra-list__label">Country</td>'));
  //Category
    SetField(fieldCategory, ImportList(PageText, GetOption('MultipleValuesCategory'), '<td class="ipl-zebra-list__label">Genres</td>'));
  // Language
  if CanSetField(fieldLanguages) then
    SetField(fieldLanguages, ImportList(PageText, GetOption('MultipleValuesLanguages'), '<td class="ipl-zebra-list__label">Language</td>'));
  // Audio Format
  if CanSetField(fieldAudioFormat) then
    SetField(fieldAudioFormat, ImportList(PageText, GetOption('MultipleValuesAudioFormat'), '<td class="ipl-zebra-list__label">Sound Mix</td>'));
  // Aspect Ratio
    Value := '';
    Value := TextBetween(PageText, '<td class="ipl-zebra-list__label">Aspect Ratio</td>', '</li>');
    HTMLDecode(Value);
    Value := RemoveSpaces(Value, true);
    if (CanSetField(fieldVideoFormat)) and (GetOption('AspectRatio') = 1) then
      SetField(fieldVideoFormat, Value);
    if (CanSetField(fieldResolution)) and (GetOption('AspectRatio') = 2) then
      SetField(fieldResolution, Value);
  // Description
  if CanSetField(fieldDescription) then
    if (GetOption('DescriptionSelection') = 0) then
      Value := TextBetween(PageText, '<section class="titlereference-section-overview">', '<div class="titlereference-overview-section">');
      //Value := TextAfter(Value, '<hr>');
      Value := TextBetween(PageText, '<td class="ipl-zebra-list__label">Plot Summary</td>', '</td>');
      Value := TextBefore(Value, '</p>', '');
      if Pos('<em', Value) > 0 then
        Value := TextBefore(Value, '<em', '');
      if Value = '' then // no long description on the page, taking the short one
    HTMLDecode(Value);
    Value := StringReplace(Value, ConvertToAscii('See more »'), '');
  // Length
    Value := TextBetween(PageText, '<td class="ipl-zebra-list__label">Runtime</td>', '</li>');
    Value := TextBefore(Value, ' min', '');
    if Value <> '' then
      SetField(fieldLength, Value);
  // Producer
    Value := TextBetween(PageText, '<h4 name="producers"', '</table>');
    FullValue := '';
      FullValue := FullValue + RemoveSpaces(Value2, true);
    SetField(fieldProducer, FullValue);
  // Writer
  if CanSetField(fieldWriter) then
    Value := TextBetween(PageText, '<h4 name="writers"', '</table>');
    FullValue := '';
    SetField(fieldWriter, FullValue);
  // AKA Name
    Count := 0;
    LastValue := '';
    FullValue := ConvertToASCII(GetPage(MovieURL+'/releaseinfo#akas'));
    FullValue := TextBetween(FullValue, 'id="akas"', '</table>');
    PickTreeAdd('Select the translated title', '');
    while Fullvalue <> '' do
      Value2 := TextBetween(FullValue, ' <td class="aka-item__name">', '</td>');  //country
      Value := TextBetween(FullValue, '<td class="aka-item__title">', '</td>');   //title
      HTMLDecode(Value2);
      HTMLDecode(Value);
      if (Pos(AKACountry(), Value2) > 0) and (Value <> originalTitle) then
        LastValue := Value;
        Count := Count + 1;
        if (Count = 1) and (GetOption('BatchMode') > 0) then
        PickTreeAdd(Value, Value);
      FullValue := TextAfter(FullValue, '</tr>');
    if Count = 1 then
      SetField(fieldTranslatedTitle, LastValue);
    if Count > 1 then
      if PickTreeExec(Value) then
  // Comments
    case GetOption('CommentType') of
      0, 1:
          Value2 := '';
          p := 0;
          FullValue := ConvertToASCII(GetPage(MovieURL+'/reviews'));
          FullValue := TextAfter(FullValue, '<div class="lister-item mode-detail imdb-user-review');
          while FullValue <> '' do
            Value := TextBetween(FullValue, '<div class="review-container">','<div class="actions text-muted">');
            if GetOption('CommentType') = 1 then
              p := p + 1;
              Value2 := Value2 + inttostr(p) + '. ';
            Value2 := Value2 + TextBetween(Value, '<div class="title">','</div>');
            Value2 := Value2 + ' (by ' + TextAfter (TextBetween(Value, '<span class="display-name-link">','</a>'),'>');
            Value2 := Value2 + #32 + 'on ' + TextBetween(Value, '<span class="review-date">', '</span>') + ')' ;
            Value := TextBetween(Value, '<div class="text show-more__control">','</div>');
            Value := StringReplace(Value, #13#10, ' ');
            Value := StringReplace(Value, '<br/><br/>', #13#10);
            Value := StringReplace(Value, '<br/>', #13#10);
            HtmlRemoveTags(Value);
            Value2 := Value2 + #13#10 + #13#10 + FullTrim(Value);
            if GetOption('CommentType') = 0 then
              break;
              Value2 := Value2 +  #13#10 + #13#10;
          HTMLDecode(Value2);
          SetField(fieldComments, Value2);
      2:
          SetField(fieldComments, '');
  // TagLine
  if GetOption('GetTagline') > 0 then
    Value := TextBetween(PageText, '<td class="ipl-zebra-list__label">Taglines</td>', '</td>');
    HTMLDecode(Value);
    if Value <> '' then
      if StrGet(Value, 1) <> '"' then
        Value := '"' + Value + '"';
      case GetOption('GetTagline') of
        1:
            if GetField(fieldDescription) <> '' then
              Value := Value + #13#10 + #13#10 + GetField(fieldDescription);
        2:
            if GetField(fieldComments) <> '' then
              Value := Value + #13#10 + #13#10 + GetField(fieldComments);
  // Trivia
  if GetOption('Trivia') > 0 then
    sleep(50);
    Value := MovieUrl;
    FullValue := ConvertToASCII(GetPage(Value+'/trivia'));
    case GetOption('Trivia') of
      1,2:
        Value := TextBetween(FullValue, '<div class="sodatext">', '</div>');
      3,4:
        Value := TextBetween(FullValue, '<div class="list">', '<div id="sidebar">');
    if Value <> '' then
      Value := StringReplace(Value, #13#10, '');
      while Pos('  ', Value) > 0 do
        Value := StringReplace(Value, '  ', '');
      while Pos('<span class="linksoda">', Value) > 0 do
        Value := StringReplace(Value, TextBetween(Value, '<span class="linksoda">', '</div>'), '');
        Value := StringReplace(Value, '<span class="linksoda"></div>', '');
      Value := StringReplace(Value, 'Link this trivia', '');
      Value := StringReplace(Value, '<div class="sodatext">', #13#10 + '- ');
      Value := StringReplace(Value, TextBetween(Value, '<script type="text/javascript">', '</script>'), '');
      HTMLDecode(Value);
      Value := RegExprSetReplace('\s[\d,]+\s+of\s+[\d,]+\sfound\sthis\sinterestingInteresting\?YesNo\|', Value, '', false);
      Value := RegExprSetReplace('\s*Is\sthis\sinteresting\?Interesting\?YesNo\|', Value, '', false);
      Value := RegExprSetReplace('Spoilers\sThe\strivia\sitems?\sbelow\smay\sgive\saway\simportant\splot\spoints\.\s*', Value, #13#10 + 'Spoilers:' + #13#10, false);
      Value := RegExprSetReplace('\s*See\salsoGoofs.*', Value, '', false);
      if (GetOption('Trivia') = 1) or (GetOption('Trivia') = 2) then
        Value := ' ' + Value;
        1,3:
              Value := GetField(fieldDescription) + #13#10 + #13#10 + 'IMDB TRIVIA:' + Trim(Value)
              Value :=  'IMDB TRIVIA: ' + Value;
        2,4:
              Value := GetField(fieldComments) + #13#10 + #13#10 + 'IMDB TRIVIA:' + Trim(Value)
  // Awards
  if (GetOption('Awards') > 0) then
    ImportAwards();
  // Rating
//   (Remove the "//" of the next two lines beginning with "Value" and add "//" to the following two lines beginning with Value
//   if you would like to import arithmetic ratings instead of IMDB's user ratings)
//    Value := ConvertToASCII(GetPage(MovieURL + '/ratings'));
//    Value := TextBetween(Value, 'Arithmetic mean = ', '. ');
// *** not sure that changing that still works, to be confirmed
    Value := TextBetween(PageText, '<span class="ipl-rating-star__rating">', '</span>');
    if Value <> '' then
      if (GetOption('RoundRating') = 1) then
        SetField(fieldRating, IntToStr(Round(StrToFloat(Value))))
        SetField(fieldRating, Value);
  if GetOption('UserRatings') > 0 then
      Value := TextBetween(PageText, '<a href="ratings" class="tn15more">', '</a>');
      if Value <> '' then
        Value := 'User Rating: ' + GetField(fieldRating) + ' out of 10  (with ' + Value + ')';
      if (GetOption('UserRatings') = 1) and (Value <> '') and (CanSetField(fieldMediaType)) then
      if (GetOption('UserRatings') = 2) and (Value <> '') then
        SetField(fieldComments, GetField(fieldComments) + #13#10 + #13#10 + Value);
// Classification  - 10/11/22 replaced with below certification code
//  if CanSetField(fieldCertification) then
//  begin
//    Value := TextBetween(PageText, '<a href="/search/title?certificates=', '</div>');
    //ShowMessage('Value: '+Value);
//    Value := TextBetween(Value, GetParam('UserCountry') + ':', '</a>');
//    if Value <> '' then
//      SetField(fieldCertification, Value);
//  end;
    Value := TextBetween(PageText, '<span class="titlereference-change-view-link">', '<div class=');
    Value := TextBetween(Value, '<li class="ipl-inline-list__item">', '</li>');
    //ShowMessage('Initial Value: [' + Value + ']');
    //ShowMessage('Initial pos: [' + IntToStr(Pos(' ', Value)) + ']');
    while Pos(' ', Value) = 1 do
        //ShowMessage('Inter pos: [' + IntToStr(Pos(' ', Value)) + ']');
        //ShowMessage('Inter Value: [' + Value + ']');
    //ShowMessage('final pos: [' + IntToStr(Pos(' ', Value)) + ']');
    //ShowMessage('Final Value: [' + Value + ']');
    if Value <> '' then
// Certification -- Use below code to get list of all US certifications for selection
//  begin
//    CertificationValues := TextBetween(PageText, '<a href="/search/title?certificates=US', '</table>');
//    PickTreeClear;
//    PickTreeAdd('Select the certification value', '');
//    while CertificationValues <> '' do
//    begin
//      Value := TextBetween(CertificationValues, GetParam('UserCountry') + ':', '</a>');  //for user's country
//      HTMLDecode(Value);
//      Count := Count + 1;
//      if Value = '' then
//      begin
//        Break;
//      end;
//      PickTreeAdd(Value, Value);
//      LastCertificationValue := GetParam('UserCountry') + ':' + Value + TextBetween(CertificationValues, GetParam('UserCountry') + ':' + Value, '<li class=');
//      CertificationValues := TextBetween(PageText, LastCertificationValue, '</table>');
//    end;
//    if Count = 1 then
//    begin
//    end else
//    if Count > 1 then
//    begin
//      if PickTreeExec(Value) then
//      begin
//      end;
//    end;
//  end;
  // MPAA rating
  if (GetOption('MPAA') > 0) then
     Value := TextBetween(PageText, '<a href="/search/title?certificates=US', '</a>');
     Value := Trim(TextAfter(Value, ':'));
     if Value <> '' then
      if GetOption('MPAA') = 1 then
        SetField(fieldComments, GetField(fieldComments) + #13#10 + #13#10 + 'Rated ' + Value);
// ***** Imports lists like Genre, Country, etc. depending of the selected option *****
function ImportList(PageText: string; MultipleValues: Integer; StartTag: string): string;
  Value, Value2: string;
  if MultipleValues = 0 then
    Value := TextBetween(PageText, StartTag, '</a>');
    Value2 := TextAfter(Value, '<li class="ipl-inline-list__item">');
  else if MultipleValues = 3 then
    Exit;
    Value := TextBetween(PageText, StartTag, '</ul>');
    Value2 := TextBefore(Value, 'See more &raquo;</a>', '');
    if Value2 = '' then
      Value2 := Value;
    Value2 := TextAfter(Value2, '">');
    Value2 := StringReplace(Value2, '<li class="ipl-inline-list__item">', ' / ');
  HTMLDecode(Value2);
  if Pos('/ ', Value2) = 1 then
    Delete(Value2, 1, 2);
  if MultipleValues = 1 then
    Value2 := StringReplace(Value2, ' / ', ', ');
  Result := Value2;
// ***** functions to import the different pictures kinds, depending of the option selected by user *****
//Import small picture from IMDB movie main page
function ImportSmallPicture(PageText: string): Boolean;
  Value: string;
  Result := False;
  Value := TextBetween(PageText, 'alt="Poster"', '/>');
  if (Value <> '') then
    Value := TextBetween(Value, 'src="', '"');
    if Value <> '' then
      //Value := StringReplace(Value, 'https://', 'http://');
      GetPicture(Value);
      Result := True;
//Import large image, building link from the small image of the movie page
function ImportLargePicture(PageText: string): Boolean;
  Value: string;
  Result := False;
    if Value <> '' then
      Value := TextBefore(Value, '._', '') + '._V1_SY' + GetParam('LargePictureHeight') + '_AL_.jpg';
      GetPicture(Value);
      Result := True;
//Image not available, import "No Poster Available" icon
function ImportPictureNotAvailable(PageText: string): Boolean;
  Value: string;
  Result := False;
  Value := TextBetween(PageText, '<div class="photo">', '</div>');
  if (Value <> '') and (Pos('"Poster Not Submitted"', Value) > 0) then
    if Value <> '' then
      GetPicture(Value);
      Result := True;
//Image from DVD Details Page
function ImportDvdDetailsPicture: Boolean;
  Value, PageText: string;
  Result := False;
  PageText := ConvertToASCII(GetPage(MovieUrl+'/dvd'));
  Value := TextBefore(PageText, '.jpg alt="', '<table class="dvd_section" cellpadding="10"><tr>');
  if Value <> '' then
    Value := TextBetween(Value, '<a href="', '">');
    if Value <> '' then
      Result := ImportFromAmazonRedirect('https://www.imdb.com' + Value);
//Image from Merchandising Links (/sales) Page
function ImportMerchandisingPicture: Boolean;
  Result := False;
  PageText := ConvertToASCII(GetPage(MovieUrl+'/sales'));
  Value := TextBefore(PageText, '.jpg" width=', '<td class=w_rowtable_colcover><a href="');
  if Value <> '' then
    Value := TextBefore(Value, '"><img', '');
    if Value <> '' then
function ImportFromAmazonRedirect(Url: string): Boolean;
  Result := False;
  PageText := ConvertToASCII(GetPage(Url));
  Value := TextBetween(PageText, '<td id="prodImageCell"', '" id="prodImage"');
//  Value := StringReplace(TextAfter(Value, ' src="'), '_AA240', '');
  Value := StringReplace(Value, TextBetween(Value, '_AA', '_'), '');
  Value := StringReplace(TextAfter(Value, ' src="'), '_AA', '');
  if Value <> '' then
    GetPicture(Value);
    Result := True;
// ***** Gets summaries for the movie, based on the plot outline given in parameter (that contains the URL to more summaries) *****
function ImportSummary(PlotText: string): string;
  Address, Value, PageText, Longest: string;
  Address := TextBetween(PlotText, '<a class="tn15more inline" href="', '" ');
  if (Address = '') or (GetOption('DescriptionSelection') = 0) then
    Result := FullTrim(TextBefore(PlotText, '<a class="tn15more inline"', ''));
    if Result = '' then
      Result := FullTrim(PlotText);
    HTMLRemoveTags(Result);
    HTMLDecode(Result);
    PageText := ConvertToASCII(GetPage('https://www.imdb.com' + Address));
    PickListClear;
    Longest := '';
    PageText := TextBetween(PageText, '<ul class="ipl-zebra-list" id="plot-summaries-content">', '</ul>');
    Value := TextBetween(PageText, '<p>', '</p>');
    PageText := RemainingText;
      Value := FullTrim(StringReplace(Value, #13#10, ' '));
      HTMLDecode(Value);
      if Length(Value) > Length(Longest) then
        Longest := Value;
      PickListAdd(FullTrim(Value));
    if (GetOption('BatchMode') > 0) or (GetOption('DescriptionSelection') = 2) then
      Result := Longest
      if not PickListExec('Select a description for "' + GetField(fieldOriginalTitle) + '"', Result) then
        Result := '';
// Import awards
procedure ImportAwards;
  IndexPage: TStringList;
  PageText, FullValue, Block, Value, Row, Outcome, Details, AwardShow, PageText1: string;
  Year, Result, Award, Category: string;
  sleep(50);
  Value := MovieUrl;
  PageText := ConvertToASCII(GetPage(Value+'/awards'));
    AwardShow := TextBetween(PageText, '<h3>', '</h3>');
    if Pos('User Lists', AwardShow) > 0 then
      break;
      HTMLRemoveTags(AwardShow);
      HTMLDecode(AwardShow);
      AwardShow := FullTrim(AwardShow);
      AwardShow := StringReplace(AwardShow, #13, '');
      AwardShow := StringReplace(AwardShow, #10, '');
      FullValue := FullValue + #32 + AwardShow + #13#10;
      PageText1 := TextBetween(PageText, '<table class="awards"', '</table>');
      Block := PageText1;
        Row := TextBetween(Block, '<tr>', '</tr>');
        Block := RemainingText;
        Outcome := TextBetween(Row, '<b>', '</b>');
        Category := TextBetween(Row, '<span class="award_category">', '</span>');
        Award := TextBetween(Row, '<td class="award_description">', '</td>');
        Details := TextBetween(Row, '<div class="award_detail_notes">', '</div>');
        If Outcome <> '' then
          FullValue := FullValue + #32 + Outcome + #13#10;
        If Category <> '' then
          FullValue := FullValue + #32 + Category;
        If Award <> '' then
          Award := StringReplace(Award, '<br />', #32);
          HTMLRemoveTags(Award);
          HTMLDecode(Award);
          Award := StringReplace(Award, #13, '');
          Award := StringReplace(Award, #10, '');
          Award := FullTrim(Award);
          Award := StringReplace(Award, '  ', '');
          FullValue := FullValue + #32 + Award;
        If Details <> '' then
          HTMLRemoveTags(Details);
          HTMLDecode(Details);
          Award := StringReplace(Details, #13, '');
          Award := StringReplace(Details, #10, '');
          Award := FullTrim(Details);
          FullValue := FullValue + #32 + Details + #13#10;
     until (Row = '');
  until (PageText1 = '');
 // ShowInformation(FullValue);
    case GetOption('Awards') of
      1:
            Value := GetField(fieldDescription) + #13#10 + #13#10 + 'AWARDS: ' + #13#10 + FullValue
            Value := 'AWARDS: ' + FullValue;
      2:
            Value := GetField(fieldComments) + #13#10 + #13#10 + 'AWARDS: ' + #13#10 + FullValue
// ***** beginning of the program *****
      if ShowWarning('Old version of file "Stringutils1.pas" detected: v'+IntToStr(StringUtils1_Version)+#13#10+'The script requires at least version 7.'+#13#10+'Download and install latest version now ?') = True then
          UpdateFile.Text := GetPage('http://update.antp.be/amc/scripts/StringUtils1.pas');
          UpdateFile.Free;
          ShowInformation('StringUtils1 has been updated. Please restart IMDB script now. Thank you.');
          Exit;
          ShowInformation('You can download latest version of "StringUtils1.pas" using script "update scripts" or via http://update.antp.be/amc/scripts');
          Exit;
  // Check for current AMC version
  if CheckVersion(4,2,2) then
    // bug with default values it seems ?
    if GetParam('MaxActors') = '' then
      SetParam('MaxActors', '10');
    if GetParam('UserCountry') = '' then
      SetParam('UserCountry', 'United States');
    if GetParam('LargePictureHeight') = '' then
      SetParam('LargePictureHeight', '720');
    MovieYear := GetField(fieldYear);
    MovieName := '';
    if GetOption('BatchMode') = 2 then
      MovieName := GetField(fieldURL);
      if Pos('imdb.com', MovieName) = 0 then
        MovieName := '';
      if not Input('IMDB Import', 'Enter the title or the IMDB URL of the movie:', MovieName) then
        Exit;
      Sleep(500);
    if MovieName <> '' then
      if Pos('imdb.com', MovieName) > 0 then
        MovieName := StringReplace(MovieName, '//imdb.com', '//www.imdb.com');
        MovieName := StringReplace(MovieName, 'http://', 'https://');
        AnalyzeResultsPage(MovieName)
      if RegExprSetExec('tt[0-9]+', moviename) then
        AnalyzeResultsPage('https://www.imdb.com/title/' + MovieName + '/reference')
          MovieName := StringReplace(MovieName, '&', 'and')
          MovieName := UTF8Encode(StringReplace(MovieName, '&', 'and'));
        if (GetOption('BatchMode') > 0) or (GetOption('PopularSearches') = 1) then
          AnalyzeResultsPage(PopularTitleSearchURL + UrlEncode(MovieName))
          AnalyzeResultsPage(FullTitleSearchURL + UrlEncode(MovieName));
  else if ShowWarning('This script requires a newer version of Ant Movie Catalog, at least the version 4.2.2, currently available as beta - do you wish to open the link to download it?)') = true then
    Launch('https://forum.antp.be/phpbb3/viewtopic.php?f=6&t=6862', '');
cialis
Post by cialis »
j'ai exactement le même problème...
Je remercie par avance ceux qui essaient de trouver une solution
Bonne journée...
bhilam wrote: 2022-10-17 22:55:50 I have updated the IMDB script (it is still a work in progress) to get it to work in most scenarios. When I get 404 or no data, I have tried re-running the script which often works fine but there are also times where I am just unable to fetch the data and ended up passing URL so that will need to be looked at. I am sure there is probably better way to fix the issue as I've only "hacked" my way thru the script.
Indeed it only works sometimes.
The version 4.017 that I made previously seems to still work in some cases, but I added extra code to handle the page layout that you tried to handle in your code.
It seems that IMDb returns randomly two different versions of the pages.
For me right now it seems to work in a stable way (version 4.018 uploaded - run the "Update scripts" to get it) but it may change again in the next days.
If you encounter problems with some movies, please report at least a sample title so I can check if it is related to the title or not (as it occurred that it was the case in the previous fixes).
cialis
Post by cialis »
antp wrote: 2022-10-19 09:57:40
Merci de faire l'effort pour trouver une solution.
Je vais faire la mise à jour...
Bonne journée...
bhilam
Post by bhilam »
Thank you for the update script. Works much better than my version :)
antp wrote: 2022-10-19 09:57:40 It seems that IMDb returns randomly two different versions of the pages.
I second that. Even searching on IMDB page randomly returns one of the two versions of the page. :shaking:
Maybe script should look for marker(s) that determine the version of the page being returned before parsing it
antp wrote: 2022-10-19 09:57:40 If you encounter problems with some movies, please report at least a sample title so I can check if it is related to the title or not (as it occurred that it was the case in the previous fixes).
I am still not able to run the script in batch mode and retrieve details often and have to keep retrying.
For the individual searches, I did see minor formatting issue (missing spaces) in "Title search results" window for following movies.
License to Wed (2007)
Here is the screenshot: https://ibb.co/x7NFyT9
The Lunchbox (2013)
Endless Love (2014)
oobaka67
Post by oobaka67 »
This worked for me for one movie. Now instead of getting a "no movie found" I get a blank page instead of a list of possible matches.
Also, I ran the "update scripts" and that changed nothing at all. It's actually gotten worse.
I've gone back to the original IMDB script that comes with the 4.2.2. download.
It at least works some of the time and, if I keep trying, it will eventually work.
cialis
Re: IMDB "No movie found" error
Post by cialis »
en ce qui me concerne, la mise à jour a bien fonctionné...
La recherche de films est efficace...pour le moment, pas de refus...
Merci encore à antp pour son efficacité.
bhilam
Post by bhilam »
oobaka67 wrote: 2022-10-22 15:12:43
Please use version 4.018 released by antp. So far it has worked "better" for me. It may not work perfectly but it is the best one available right now.
bhilam wrote: 2022-10-19 16:19:52 For the individual searches, I did see minor formatting issue (missing spaces) in "Title search results" window for following movies.
Yes, indeed, I still have to fix that
