Group by...DVD?
LucMa
Group by...DVD?
Post by LucMa »
Hi:)
I like organize my movie's list in order by DVD, the only way that i have find to do that is set AMC Group by number but i can't rename the number with a world. There is a way in order to obtain this?
for example:
Spielberg:
ET
Close Encounters of the Third Kind
Minority Report
Tarantino:
Kill Bill 1
Kill Bill 2
etc..
is possible?
Thank's and bye :)
The field "Media Label" was made for that ;)
LucMa
Post by LucMa »
NO :cry: media label sort all my movie in the same group
first i have my list in this format
1 (3)
- 1 ET
- 1 Close Encounters of the Third Kind
- 1 Minority Report
2 (2)
- 2 Kill Bill 1
- 2 Kill Bill 2
ect
with media label i have
none (386)
1 ET
1 Minority Report
2 Kill Bill 1
2 Kill Bill 2
are all in the same group named "none"
Sorry if i explain no good, i want see my list in this mode
Spielberg:
- ET
- Close Encounters of the Third Kind
- Minority Report
Tarantino:
- Kill Bill 1
- Kill Bill 2
what i must do for change the "none" name with the director's name of the film?
what i must do for have the movie not in ONE bug list but separated by dvd (director's)?
Many thank's :)
But then you have to put the group name in the media field :p (and you have some options to put movies of "none" group outside anygroup)
But if you want to have groups by director, why not group by director field :??:
LucMa
Post by LucMa »
sorry but i can't translate correctly your answer, can u speak easy please?
i can' order by director becouse i have some movie where are some component and aren't exactly in the list.
An example, i have the movie Angel heart by Alan Parker but i haven't it one the Alan Parker DVD but in the Mickey Rourke dvd
So, don't know why i can't rename the group :ha:
The best is that i enter the dvd in my DVD, AMC read the movie and request me the name that i want made to the Group.
After i order my catalog by name or the DVD and i see a list like
Musical
Commedy
Tarantino
Spielberg
and if i want see the movie in the Tarantino group i click on in and i see the list
This is the only way speed for find a movie. Don't know why there is no this option :mad:
That's why I suggested you to use Media Label.
Put the name of the group in the "Media Label" field of each movie.
So there is a possibility to get what you ask :p
LucMa
Post by LucMa »
ok, now is perfect..last question and i stop bugging you :D
now i have the movie order by label but the number aren't consecutive, for example, i have:
Kubrick
23 - A Space Odyssey
44 - Eyes Wide Shut
Polansk
13 - Le pianiste
80 - Le locataire
Is possible re-order the movie in consecutive alphabetical numbers?
the best if is possible that all the movie have the same number when are in the same label, like
Kubrick
11 - A Space Odyssey
11 - Eyes Wide Shut
Polansk
12 - Le pianiste
12 - Le locataire
Is possible?
Many thank's..for your patience :)
You will have to modify the number of each movie then.
An automatic solution : if you want for example
Kubrick
12 - Eyes Wide Shut
Polansk
13 - Le pianiste
14 - Le locataire
is to use "Tools" -> "Renumber". Then select "advanced", and select the fields MediaLabel followed by Number.
Teebee
Post by Teebee »
This is the way I should do it:
Export list to csv, import it in Excel / openoffice Calc, change the numbers, and export it back to .csv, which i then import again in amc.
Or press F2 and change it manually, if the list isnt really big.
Or use the automatic way antp suggested :o
LucMa
Post by LucMa »
many thank's for your help :grinking:
