Specific scripts > shortcut?
Sorin
Post by Sorin »
I have one questions about scripts.
So... I want to put specific scripts (for example "IMDB") like shortcuts in main toolbar.
It's any possibility to do that?
Thanks!
If you only use one script you have an option to auto-run it.
But it is currently not possible to have shortcuts to scripts (it is planned in a future version).
Sorin
Post by Sorin »
Thanks 4 answer, but...
Please, consider this (before future version) : if i delete all scripts from scripts folder (of course, except IMDb!) do i have any possibillity that after click on scripts shortcut or F6 go directly on IMDb and search concrete movie?
I mean - maybe some litlle modifications help me to do that (like 4 duplicates :))?
And one more suggestion for modifying IMDb scripts - if user pick option 1 or 2 in "Awards" Script options ("Import awards to Description/Comments fields"), then if movie have some awards, on the end of awards list absolutely redundantly stay :
"You may report errors and omissions on this page to the IMDb... ...A B C D E F G H I J K L M N O P Q R S T U V W X Y Z Other"
So, any chance to remove this?
Thanks again! I very appreciate your work.
You do not have to delete scripts for that, there is an option to autorun last script in the "Preferences" window.
Can you give an example of movie that cause the problem with awards ?
Sorin
Post by Sorin »
No, this is not a big problem.
Simply, on the end of awards list (at any movie who have at list one awards) every time is overage, unnecessary text.
Text is : "You may report errors and omissions on this page to the IMDb... ...A B C D E F G H I J K L M N O P Q R S T U V W X Y Z Other".
Yes but I mean that, if it only happens with some movies, I need to know which movies cause it. If it happens with all movies that have award info, then I'll fix it as soon as possible ;)
Sorin
Post by Sorin »
Yes, it happens with all movies that have award info.
