Sort by traslated titles
SteM
Post by SteM »
Hi everybody,
how can i sort the movie list by translated title ?
I'm sorry but i'm not able to do it ?!?!?! :(
Thanks !
If some translated field are empty, the best is to sort by formatted field and define (in the preferences) that formatted field = "translated (original)"
SteM
Post by SteM »
I'm sorry,
but i don'understand ... i have no blank translated titles....
Where in the Preferences page, please ?
I have always sort by movie number (and grouping by label)
You mean in the main window or for exporting/printing?
In the main window you can simply click on the "Title" header of the list to change the sort, like in Windows Explorer and lots of other programs
SteM
Post by SteM »
Yes . :cry: . it was simple ...
Thanks a lot
DRAG@N
Post by DRAG@N »
and for exporting/printing, you can do as antp said before :
[...]the best is to sort by formatted field and define (in the preferences) that formatted field = "translated (original)"
Howto :
Tools > Preferences > Title formatting > Title to display = "Translated title (Original title)"
Then :
- for the main window : Tools > Renumber > Formatted Title :o
- for exporting : Export > Sort By = Formatted Title
edit : oups, I'm confused :ha:
Renumber is to renumbering, not for sorting :p
