Mediaman has gone shareware and I use or should I say used both Mediaman and Ant, but I know theres lots of folks out there now going to discover Ant because of Mediaman's move to shareware, so my question is whats the easiest way to import mediaman db's to Ant, I tried csv just to see but the Ant just hung up and thats just exporting Title to a csv file nothing else.
Any ideas may help people in the future.
Thank-you
Mediaman import help
Kalynuik
Kalynuik
This file is strange, the tab separators seems to be wrongly placed (the number of columns does not correspond to headers) and there are line breaks inside some lines.
Unfortunately it will not be easy to convert them propertly I guess
And I'll not be able to make a direct importation:
What's the format of MediaMan Collection File? Can I have it?
MediaMan Collection File is a private binary file format developed by myself. It's by no means known by a second person, nor am I planning on opening it to the public.
Kalynuik
Yes I noticed that as well, just to impot the titles alone, nothing else exported I had to load the csv into NoteTab Standard (I use this all the time for text) and I had to find and replace ^T (Tabs) and eliminate triple commas ,,, then saved as a regular text file named .csv then it imported.
Good thing I was willing to update all manually in Ant otherwise the conversion alone of the original csv file would have made me an old man.
Anyways good-luck and thank-you
