Import data from local SQL database
khepper
Post by khepper »
I'm my movies catalog into a mysql database from years ago. I want to complete this information and update with ant movie catalog but i dont see how can i make it.
How can i import data from SQL database? I see it's possible export to SQL but not import
Thanks for your help
MaximusDM
Post by MaximusDM »
Hello Khepper,
You can export your data from phpMyAdmin in CSV wich is supported by AMC import ;)
P.S. : sorry for my english :p
khepper
Post by khepper »
Thanks MaximisDM, well, my structure is not the same, but i think this can be repaired.
I tell you if i can export.
Sorry but my english neither is good, but is not a problem ;)
