Is such a template available ?
Teebee
Post by Teebee »
I was wondering if there is a template available (html), which makes it possible to click on NEXT / PREV and it loads the next movie, and on the left side it has the complete list.
Or is it possible to change my current html code so it adds the NEXT / PREV button ?
<html><head>
<LINK REL="stylesheet" href="movies.css" TYPE="text/css">
</head><body class="moviecard">
<table class="lgt" cellspacing="0" cellpadding="5">
<tr><td class="lgt">
<table class="i" border="0" cellspacing="0" cellpadding="1" width="100%">
<tr>
  <td colspan="3" class="iblk"><div class="title">$$ITEM_ORIGINALTITLE</div></td></tr>
<tr>
  <td class="iwh" rowspan="10" width="120">$$ITEM_PICTURE</td>
  <td class="igr"><font size="+1">Ondertitels:</font><br><font size="+1">FORMAAT:<br></font><br><br>Regisseur:</td>
  <td class="iwh"><font size="+1">$$ITEM_SUBTITLES<br></font><font size="+1">$$ITEM_MEDIA</font><br><br><br>$$ITEM_DIRECTOR</td></tr>
  <td class="igr">Acteurs:</td>
  <td class="iwh">$$ITEM_ACTORS</td></tr>
  <td class="igr">Land:</td>
  <td class="iwh">$$ITEM_COUNTRY</td></tr>
  <td class="igr">Categorie:</td>
  <td class="iwh">$$ITEM_CATEGORY</td></tr>
  <td class="igr">Jaar:</td>
  <td class="iwh">$$ITEM_YEAR</td></tr>
  <td class="igr">Score:</td>
  <td class="iwh"><img src="images/$$ITEM_RATING.png" width="129" height="13" alt="$$ITEM_RATING" border="0"> ($$ITEM_RATING/10)  </td></tr>
<hr class="blk">
    <td class="igr">Taal:</td>
  <td class="iwh">$$ITEM_LANGUAGES</td></tr>
  <td class="igr">Lengte:</td>
  <td class="iwh">$$ITEM_LENGTH</td></tr>
</table><hr class="blk">
<table class="i" border="0" cellspacing="0" cellpadding="1">
  <td class="igr" width="120">Bespreking:</td>
  <td class="iwh">$$ITEM_DESCRIPTION</td></tr>
</tr></td></table></body></html>
its based on template3.zip
I do not think that it is possible with plain HTML.
With few Javascript it should be easy to do.
Teebee
Post by Teebee »
I'll ask around then if someone is capable of making that ;)
I have also a question about exporting to html.
Is there some sort of command to replace text in fields ?
When i export my list, it outputs it like this:
Julie Andrews (as Maria)
Christopher Plummer (as Captain Georg von Trapp)
Is there a way so it removes the "as " so i would get this:
Julie Andrews (Maria)
Christopher Plummer (Captain Georg von Trapp)
It could be done with a script, but this would modify the catalog, not only the export.
Teebee
Post by Teebee »
And also a question about importing csv files:
Is there a way so it uses the first row as an indicator which column has to be used for a available field, so that way when you load an csv, the fields are allready in place?
Otherwise i will have to export my list to excel, replace those "(as " and import it again. I allready modified the script so next time it isnt included when grabbing the info.
In current version, no, you have to re-assign fields.
In next version it will detect fields.
But as I said with a script it is easy:
program RemoveAs;
  SetField(fieldActors, StringReplace(GetField(fieldActors), '( as', '('));
You can also do this in the IMDB script just after the SetField of fieldActors (or modify the SetField line).
Teebee
Post by Teebee »
I have modified the imdb script, which works fine now.
I changed above script, because it didnt work for me.
Code:
program RemoveAs;
SetField(fieldActors, StringReplace(GetField(fieldActors), 'as ', ''));
Actually it should have been '(as ' rather than '( as', it's my fault ;)
