Correct the ItemNumber
dent0n
Post by dent0n »
I have another question, probably it's something easy, something what I've missed...
I have about 500 movies, some of them are on 2CDs, and when I've imported from xls/csv I had to delete the "second" CD of every 2CD movie - because I want this to be Movie List not Media/Movie List (I don't want the information of how many CDs this movie is on directly on the list - for this is the [ItemDisks]).
So, now I have numbers like: 1, 3, 5, 7, 8, 9, 11... etc. How to make AMC to re-number from the top all of my movies?
I hope that is quite clear ;)
Tools -> Renumber :D
dent0n
Post by dent0n »
Sorry, I should use English in AMC instead of translated language /Polish/ - translation was "sort" not "renumber" and that got me confused...
I'm not an idiot btw :P
Thx :-)
___
I've tried to send e-mail to person who did polish translation, but (?) his email is dead. You should send him this note - renumber isn't sort.
If there is only few items to change, you can open polish.lng with the notepad, modify the items, and send me the updated file ;)
I guess he made this mistake because in the renumber window, the program asks how the movie have to be sorted before being renumbered.
dent0n
Post by dent0n »
OK, I'll use AMC little while, maybe I'll found some more and then I'll send it to you.
regards.
--- I've send corrected language file. ---
