Sorting of Unicode titles
It may be a question actually, but anyways - I see that sorting of the sorting of the international titles leads to some stange order. I have many Russian titles in the database which I enter in Russian/Cyrillic (naturally ;) ) In the title list it all gets messed-up, with the russian titles getting interspersed with the english titles (but the english titles seem to be in order.) How is the sorting of the intenational titles done in AMC?
Unicode is not supported at all actually.
It only uses "ANSI" functions. The sorting is done using Windows' functions to compare text strings. So this depends of your locale settings. I do not know how Cyrillic should be sorted, but if the sort is wrong maybe it's something in your Windows settings that causes that :??:
OK, thanks for reply. I'm not an expert in Windows programming, but many other applications that I have installed work correctly with the international texts.
Maybe they're unicode actually :D
