Access violation if I want print something
McPringle
Post by McPringle »
Good morning!
I just installed the newly released version 3.5.0 over the old 3.4.<cantremeber>. Then I added a new movie and now I want print the DVD covers. But when I click on the print icon I get an access violation:
Access violation at address 00422983 in module 'MovieCatalog.exe'. Read of address 0000000C.
After clicking 'OK' a new message appears:
Error reading frReport1.ReportForm: Access violation at address 006412BD in module 'MovieCatalog.exe'. Read of address 00000030.
I'm actually running Windows XP SP2 with all available patches installed.
What can I do?
Thanks for this great app
McPringle
It happens even before the print window is displayed?
If you create a new file and click Print, does i crash too?
McPringle
Post by McPringle »
antp wrote:It happens even before the print window is displayed?
Yes, thats right. I see "searching for printers" (in German, I use German translation) an before displaying the dialog box I get the access violation.
Now I created a new file (didn't save it). When I click printing I get the same error. I tried it with saving the file before clicking print but with the same result.
My files are on a file server, so I checked it again locally - but nothing changed, same error...
Any ideas?
Thanks for your fast reply!
McPringle
McPringle
Post by McPringle »
I got it! The was a network printerconfigured in Windows which wasn't available any more. There should be added a check in Ant Movie Catalog, I suggest.
McPringle
The code that searches for printer is not made by me, I use FreeReport for that.
Seeing the error address (low number, 0000000C) I may be able to correct it easily, I'll check that, thanks for the info ;)
ysirider
Same error
Post by ysirider »
Je rencontre un problème identique à cet utilisateur lorsque je veux imprimer. Mon environnement est Windows XP SP2 :
access violation at address 00422983 in module "MovieCatalog.exe" Read adress 000000000C
Y-a-t il un correctif prévu ?
En tout cas merci pour ce merveilleux programme qui nous facilite tant la vie
:hihi: :hihi:
Si c'est le même cas que celui décrit précédemment, c'est parce que l'imprimante par défaut n'est pas accessible (imprimante réseau par exemple).
Il suffit de changer l'imprimante par défaut dans Windows.
