Version 3.5.0
What's new in Ant Movie Catalog, beta versions, etc...
Version 3.5.0
After a long time (one year after version 3.4.3 which was only a minor version, and much longer after last real new version) the version 3.5 is ready.
Lots of people already tested it with the large amount of beta & RC versions that I released, but now I recommend to everybody to update to this version since it is probably more stable than version 3.4.3 was.
Download page
What's new in this version
Update to include lots of new/updated scripts, some translation updates, and the following bugs corrected:
- when selecting several movies by holding Ctrl, it should not jump to previously selected movie
- imported file info (F7) should always be saved
- fullsize picture window (when clicking small picture) should be correctly adjusted to fit the screen when it is too large
- "Stop" button of scripting window was not enabled until the script was paused on a breakpoint, so it was not possible to stop the exection without setting a breakpoint (annoying when there is an infinite loop)
- images export: now it exports only selection if asked
- if picture contents is not recognized, uses extension (useful for some pictures made by ACDSee that were working in v3.4 but not in 3.5)
- few corrections made in scripts window: when a script was not in the same folder than the other script its properties and options were not working correctly. Maybe I added new bugs by correcting that, so do not hesitate to notify me if you see something strange there.
- bug with number of new movies when using first available number
- Error when selecting a printing template after a selection of "fred.frf"
At the same time, I added an option to show picture info in the fullsize picture window. The option is located in Tools -> Prefs -> Movie info -> "Show picture size etc.". It is disabled by default. It was a new feature of AMC 3.5 but lots of people found that "ugly" :hihi: (they're right, it was not really beautiful)
Update to include some scripts updates (IMDB, Allociné and few others), a Macedonian translation, and the version 0.6 of MediaInfo.
Again an update for the scripts
And again, an update for the scripts :D
Update of the install for the large amount of scripts that were updated.
and again...
and again (I should have done this before, due to the IMDB site change)
Script update, as IMDB, Allociné and few others were outdated. Time also to include a much improved version of "update scripts" script.
Galician and cyrillic Serbian translations were also added.
