Update data using given imdb url
Is there a script that uses the imdb url for getting info from imdb site, so you have the right movie ?
joly
Post by joly »
Forgot to login :ha:
I found out that looking for original title: job solved my movie problem for that one, but i cant get it to find the Rookie (1990)
Thats why i wondered if there isnt any script that would just get the data from imdb with the url i provided, so instead of searching for the original name, it just goes to the url that was filled in at URL:
As I said, it is easy to modify (if there was one, I would simply have given it in the other topic :p) but I'll do that later.
I should rewrite parts of this IMDB script, so I will do this change at the same time.
I will do that before the end of the week.
joly
Post by joly »
thank you. I wanted to respond in the other thread, but it was allready closed.
Anyway, i love your program, so keep up the good work.
Goe Bezig zoals wij hier zeggen :grinking:
