Appending doesn't work for batch files
guest
Post by guest »
Just starting to use this great program, but I've found that using the command line version doesn't appeand extensions, but replaces them.
The XML file contain the same line whether it's a extension change
<ChangeExt NewExt=".ext"/>
or an "append"
Brian
Thanks a bug, thanks for notifying me.
It will be corrected at next update ;)
