Amazon (large pic) modify for working
MercurieVV
Post by MercurieVV »
May be amazone change some code, but many pictures have not downloaded. I correct a code for that plugin, for normal work.
Its around #105 line
    if (FindLine('Below are results for',AmazonPageNOHTML,0) <> -1) OR (FindLine('All results',AmazonPageNOHTML,0) <> -1) OR (FindLine('Results for',AmazonPageNOHTML,0) <> -1) OR (FindLine('Most popular results for',AmazonPageNOHTML,0) <> -1) then
I add a search condition 'Results for'.
Thanks for the info :)
Sanaa
Post by Sanaa »
Where is in Imdb script search result (Years) of Movies?
sorry, I do not understand your question :??:
KoVaR
Post by KoVaR »
it's not working :(
What's the problem ?
If you get an error when running the script, try to remove the "NOHTML" parts from the above code.
Earlier in result of search was year of movie release,but now it is not present
Ex: Mummy, The (2002)
Mummy, The (1968)
Mummy, The (1922)....
now: Mummy, The
Mummy, The
Mummy, The
you mean IMDB ? (this thread was about Amazon)
IMDB script has been fixed : viewtopic.php?t=1678
antp wrote:What's the problem ?
Just tried that and still not working
Script error: AMAZONIMPORT at position 3230 (then expected)
please copy the full line where the error is, including 1 or 2 previous and next lines ;)
Sanaa
Post by Sanaa »
Sorry, i did no see
thanx
but (for imdb (big)+amazon script) sometimes big pictures do not downloaded, for example it is possible to check up on "Scary movie"
If i start "Sacary movie 1", picture big, if second part - small picture
I know, there are problems with IMDB big picture script, but that's since a long time.
KoVaR
Post by KoVaR »
OK....
I am not sure if I did this corretly
It goes like this:
Amazon (large pic).ifs stopped working
As MercurieVV suggested I replaced this line (line # 103)
   if (FindLine('Below are results for',AmazonPage,1) <> -1) OR (FindLine('All results',AmazonPage,1) <> -1) OR (FindLine('Most popular results for',AmazonPage,1) <> -1) then
with this one
Now Im getting this error I wrote about, in this line
(I also tried removing NOHTML from it but no effect)
I start to think I did something wrong...
How should I understand this sentence:
Except if a string (text between '...') is cut on two lines, I do not know what could cause a problem :/
KoVaR
Post by KoVaR »
so...
Is there any working Amazon large pic script ?
For me it works with the modifications from first post of the topic :
http://antp.be/temp/scripts/Amazon%20(large%20pic).ifs
KoVaR
Post by KoVaR »
It's working :grinking:
but how so I update imdb script to get images from amazon ?
simply adding amazon script at the end of imdb script will do it ?
No, it is not so easy.
And if it was easy, I would have done it already :p
