i think imdb script is broken
mickey99
Post by mickey99 »
when there is two movies of the same name, there is a dialog for you to choose, before there is the year of movie is make now it is gone.
I guess that IMDB site changed a little.
Now the years are not in the title links but just after them, so the script cuts them.
I'll correct that as soon as possible, except if somebody else corrects it.
mikey99
Post by mikey99 »
thanks for the fix.
KoVaR
Post by KoVaR »
Could you pls post what has been hanged instead of posting entire script ?
thnx
if I remember well, in AddMovieTitles I modified this line:
MovieTitle := Copy(Line, StartPos, Pos('</td>', Line) - StartPos);
and added the following just after:
HTMLRemoveTags(MovieTitle);
DJDoubleD
Post by DJDoubleD »
Hi
I tried the 3 scripts u posted here, but they still return a window saying "No movie found"
for titles which return more then one result on the imdb site. Titles that return only 1 result still work.
I tried it for "The Village" and "Wimbledon".
The last one still worked yesterday.
If it was working yesterday, a script corrected two weeks ago cannot fix something that changed today :p
I do not have to check that now unfortunately.
JoeLansing
IMDB script change...
Post by JoeLansing »
Ok.. I've been adding about 4 movies a day for months now. Now that it's broke, I realize how much I need this program. Time to get out the card and send $25 or so. Darn Micro$oft would leave us hanging on a problem like this, or blame IMDB. Thanks Antp!
Until it is fixed you can import info from other sites... or simply wait few days :p
DJDoubleD
Post by DJDoubleD »
antp wrote:If it was working yesterday, a script corrected two weeks ago cannot fix something that changed today :p
Indeed... (unless u had travelled back in time :hum:)
I only looked at the date of your last post (where u explained the changes u made) and did not notice the date for the post with the 3 files was different.
My bad :)
KaraGarga
Post by KaraGarga »
I think i've fixed it :)
IMDB seems to change everything in search module. Therefore I have add new procedures from All Movie script, because their background became similar.
I'm not professional. There might be better solutions :D
Anyway this one works... Hope it'll help...
IMDB (Small Picture)
// GETINFO SCRIPTING
// IMDB (US) import with small picture
 *      IMDB (US), http://us.imdb.com              *
 *  (c) 2002-2004 Antoine Potten                   *
 *                          software@antp.be       *
 *  Contributors :                                 *
 *    Danny Falkov                                 *
 *    Kai Blankenhorn                              *
 *  www.antp.be/software/moviecatalog              *
 *  This program is free software; you can         *
 *  redistribute it and/or modify it under the     *
 *  terms of the GNU General Public License as     *
 *  published by the Free Software Foundation;     *
 *  either version 2 of the License, or (at your   *
 *  option) any later version.                     *
program IMDb;
  DescriptionToImport = 2;
      2 = import longest
      1 = import short (from main page, faster)
      0 = display list to select a description
  MovieURL: string;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
// Extracts single movie detail (like director, genre) from page
  Result := '';
    CutBefore(Page, StartTag);
    if Length(CutTag) > 0 then
      CutAfter(Page, CutTag);
    // remove html tags and decode html string
    HTMLRemoveTags(Result);
    HTMLDecode(Result);
//  ShowMessage('DEBUG: GetStringFromHTML - StartTag "'+StartTag+'", CutTag "'+CutTag+'", EndTag "'+EndTag+'", Result "'+Result+'" ___ '+Page);
  if pos('<title>IMDb', Page.Text) = 0 then
    AnalyzeMoviePage(Page)
      PickTreeAdd('Search results', '');
      AddMoviesTitles(Page);
      AnalyzePage(Address);
  BeginPos, EndPos, DescrImport: Integer;
  DescrImport := DescriptionToImport;
  if (DescrImport <> 1) and (Pos('<a href="plotsummary">', Page.Text) = 0) then
    DescrImport := 1;
  MovieURL := 'http://imdb.com/title/tt' + Copy(Page.Text, Pos('<option>Your Vote</option>', Page.Text) - 9, 7);
  // URL
  SetField(fieldURL, MovieURL);
  // Original Title & Year
  if LineNr > -1 then
    BeginPos := pos('<title>', Line);
    if BeginPos > 0 then
      BeginPos := BeginPos + 7;
    EndPos := pos('(', Line);
    if EndPos = 0 then
      EndPos := Length(Line);
    HTMLDecode(Value);
      EndPos := Pos('/I', Line);
      if EndPos < BeginPos then
        EndPos := Pos(')', Line);
      SetField(fieldYear, Value);
  // Rating
  if LineNr > -1 then
    if Pos('/10', Line) > 0 then
      SetField(fieldRating, Value);
  // Picture
  LineNr := FindLine('<img border="0"', Page, 0);
  if LineNr > -1 then
    BeginPos := pos('src="', Line) + 4;
    Delete(Line, 1, BeginPos);
    EndPos := pos('"', Line);
    GetPicture(Value, False); // False = do not store picture externally ; store it in the catalog file
  // Director
  if LineNr > -1 then
    FullValue := '';
      EndPos := pos('</a>', Line);
        if FullValue <> '' then
      Delete(Line, 1, EndPos);
    until Pos('</a>', Line) = 0;
    HTMLDecode(FullValue);
  // Actors
  LineNr := FindLine('ast overview', Page, 0);
  if LineNr = -1 then
    LineNr := FindLine('redited cast', Page, 0);
  if LineNr > -1 then
    FullValue := '';
      BeginPos := Pos('<td valign="top">', Line);
        if EndPos = 0 then
          EndPos := Pos('</td>', Line);
          BeginPos := pos('.... </td><td valign="top">', Line);
            EndPos := pos('</td></tr>', Line);
            BeginPos := BeginPos + 27;
            if Value2 <> '' then
              Value := Value + ' (as ' + Value2 + ')';
        Line := '';
    until Line = '';
  //Country
  LineNr := FindLine('Country:', Page, 0);
  if LineNr > -1 then
    HTMLDecode(Value);
  //Category
  LineNr := FindLine('Genre:', Page, 0);
  if LineNr > -1 then
    HTMLDecode(Value);
  //Description
  LineNr := FindLine('Plot Summary:', Page, 0);
  if LineNr < 1 then
    LineNr := FindLine('Plot Outline:', Page, 0);
  if LineNr > -1 then
    BeginPos := pos('</b>', Line) + 5;
    EndPos := pos('<a href', Line);
    if EndPos < 1 then
      EndPos := pos('<br><br>', Line);
      if EndPos < 1 then
    HTMLDecode(Value);
    case DescrImport of
      0:
          PickListClear;
          PickListAdd(Value);
          GetDescriptions(GetField(fieldURL) + 'plotsummary');
          if PickListExec('Select a description for "' + MovieName + '"', Value) then
      1:
      2:
        SetField(fieldDescription, GetDescriptions(MovieURL + 'plotsummary'));
  // Comments
  LineNr := FindLine('<b>Summary:</b>', Page, 0);
  if LineNr > -1 then
    Value := '';
      LineNr := LineNr + 1;
      EndPos := Pos('</blockquote>', Line);
      if EndPos = 0 then
        EndPos := EndPos - 1;
      Value := Value + Copy(Line, 1, EndPos) + ' ';
    until Pos('</blockquote>', Line) > 0;
    HTMLDecode(Value);
    Value := StringReplace(Value, #13#10+' ', #13#10);
  // Length
  LineNr := FindLine('Runtime:', Page, 0);
  if LineNr > -1 then
    EndPos := pos(' min', Line);
    if EndPos = 0 then
      EndPos := pos('  /', Line);
    if EndPos = 0 then
    if Pos(':', Line) < EndPos then
      BeginPos := Pos(':', Line) + 1
      BeginPos := 1;
    SetField(fieldLength, Value);
  // Language
  LineNr := FindLine('Language:', Page, 0);
  if LineNr > -1 then
    if EndPos = 0 then
  DisplayResults;
function GetDescriptions(Address: string): string;
  Line, Value: string;
  BeginPos, EndPos,Longest: Integer;
  Result := '';
  Longest := 0;
  LineNr := FindLine('<p class="plotpar">', Page, 0);
  while LineNr > -1 do
    Value := '';
        BeginPos := BeginPos + 10
        BeginPos := 1;
      EndPos := pos('</p>', Line);
      if EndPos < 1 then
        EndPos := Length(Line) + 1;
      if Value <> '' then
        Value := Value + ' ';
    until (pos('</p>', Line) > 0) or (LineNr = Page.Count);
    HTMLDecode(Value);
    PickListAdd(Value);
    if Length(Value) > Longest then
      Result := Value;
      Longest := Length(Value);
    LineNr := FindLine('<p class="plotpar">', Page, LineNr);
procedure AddMoviesTitles(ResultsPage: TStringList);
  Page: string;
  Page := ResultsPage.Text;
  while Pos('<a href="/title/tt', Page) > 0 do
    CutBefore(Page, '<ol><li><a href="/title/');
    MovieAddress := 'http://imdb.com' + GetStringFromHTML(Page, '<li><a href="', '"', '?fr=');
    MovieTitle := GetStringFromHTML(Page, 'fm=1">', '">', '</li>');
    CutAfter(Page, '</li>');
  if CheckVersion(3,4,0) then
    if Input('IMDb Import', 'Enter the title of the movie:', MovieName) then
      AnalyzePage('http://imdb.com/find?more=tt;q='+UrlEncode(MovieName));
KaraGarga
Post by KaraGarga »
Just for information:
I've added these procedures:
  Result := '';
    HTMLDecode(Result);
completely changed:
  Page: string;
and small changes:
Thanks !
Bronx
Post by Bronx »
I just have to THANK YOU for this program :grinking:
I had the "No Movie Found" for the first time yesterday. I search the forum and found my solution.
Again thank you ANT for this great software.
Dizzy
Post by Dizzy »
Thanks for a new script guys :grinking:
But the new script does not include comments, can this be added? or is there a problem with the new IMDB website structure?
It should be included... maybe that this part of the site changed too.
I'll check that later.
KaraGarga
Post by KaraGarga »
When i fixed it yesterday, there were no problem with comments. Today they changed something and make new addition on "Main Details" page.
I think i fixed. This one seems to work well :) Just change above script old "Comments" part with this one...
  // Comments
  LineNr := FindLine('/comments">', Page, 0);
  if LineNr > -1 then
        Value := '';
      EndPos := Pos('"', Line);
      if EndPos = 0 then
    until Pos('"hidden"', Line) > 0;
    HTMLDecode(Value);
    Value := StringReplace(Value, '"', '"');
    Value := StringReplace(Value, '&', '&');
    HTMLRemoveTags (Value);
    Value := StringReplace(Value, '    ', '');
Ant, you're real programmer (not like me :D) So there would be mistake in my corrections. Please free to change any bugs or mis-coded part, my purpose is just to offer solutions. Maybe there would be better solutions that i don't know :)
Thanks for this scripting utility by the way. It makes developing and correction scripts easily (even by me :D)
Thanks, no problem if it is not a very clean code, soon I'll rewrite properly all the IMDB scripts so it will be compliant with AMC 3.5 (with new options system only one global script will be needed)
