[EN+others] NEW SCRIPTS REQUESTS : CLICK HERE TO DO THEM
Please do you requests for new scripts for new sites in this topic rather than create a new one each time.
Thanks.
There is no garantee of result : if someone wants to make one of the requested script, he can do it and he is welcome, but I won't personnally make new scripts on request (I already have too few time for working on the program).
If you make a new script, it is better to create a new topic for it and (if you want) post a link to this topic here rather than directly put the script here, to keep this topic readable.
A note for french users :
Pour toute discussion en français, merci d'utiliser l'autre topic.
-xD-
Post by -xD- »
http://sharereactor.ru/
dont work good
Script 4 amazon.com (audio)!!! please!!!
Dmitry501
sharereactor.ru
Post by Dmitry501 »
Replace ShareReactor (RU) (large pic).ifs from string #82
  // Original Title & TranslatedTitle & Year
   LineNr := FindLine('&nbsp', Page, 0);           //Ïîèñê èìåíè ôèëüìà ÐÓÑ
   if LineNr > -1 then
    BeginPos := pos('<H1>', Line);
    if BeginPos > 0 then
      BeginPos := BeginPos + 4;
    EndPos := pos('</H1>', Line);
    Value := copy(Line, BeginPos, EndPos - BeginPos+1 );
    HTMLRemoveTags(Value);
    HTMLDecode(Value);
for fix TranslatedTitle and from # 124 string
   //Category
   LineNr := FindLine('&nbsp', Page, LineNr+1);        //Æàíð
   if LineNr > -1 then
    BeginPos := pos('("', Line);
      BeginPos := BeginPos + 2;
    EndPos := pos('")', Line)-1;
    HTMLDecode(Value);
for fix Category
p.s. (String number maybe is different from your file and me) :(
-xD-
Post by -xD- »
а ты можешь сделать на amazon.com для аудио?
ну просто очеь нада! так очень что я перепробовал все проги.... :(((
спасибо за шару скрипт!!!
KoVaR
Post by KoVaR »
Hi
could someone tell how to modify imdb script so that tagline would imported into comments field
thnx :cool:
Sanaa
Post by Sanaa »
picture from this script not downloaded :(
thanx for fix "category" and "name"
KoVaR wrote:Hi
thnx :cool:
In the latest version I added an option to get the tagline ;)
joly
Post by joly »
Automatic update from all films, without having to click for each movie.
and getting the data from the given url:
AnalyzePage(GetField(fieldURL));
instead of
// analyzePage('http://imdb.com/find?more=tt;q='+UrlEncode(MovieName));
is that possible ?
If you want to run a script for selected movies rather than only current movie, use Tools -> Scripting
joly
Post by joly »
Well, when i select 1000 movies, and press F6, select IMDB script and only select RATING in the Modifiable fields, i still have to press ENTER for each movie. BUt every movie has already the correct url, and because
instead of
doesnt seem to work anymore, because it is old script, i have to manually click for every movie OK, and get the selection of possible movies and because choosing batchmode 1 sometimes chooses the wrong movie.
In 3.4.3 i just replaced the line with AnalyzePage(GetField(fieldURL)); and it went trough the complete list without having to click all the time.
And i dont know what to change so it would work in 3.5.0 beta 3
And using the old one isnt an option, because i want it for the comma eg. 7.1 rating.
you also have to remove the if Input(...) if you do not want it to ask for the title
In the future, I'll add to batch mode the option to use the URL field
polnjumen
Post by polnjumen »
You can simply modify IMDB script like this:
// ***** beginning of the program *****
  if CheckVersion(3,5,0) then
    MovieName := GetField(fieldURL);
and set batchmode to 1
Hi, is someone here who has time to update script for www.allmove.com for AMC v3.5.
Its a great site!
I try with the toll called "ScriptConverter" posted in other topic. The script works but not perfectly. Some fields are messed up.
Thank you.
zile
Post by zile »
ouch, forgot to login and made a mistake about the name of the site.
Its www.allmovie.com of course. :)
REQ: some anime database script
i saw someone already requested an EN anime database script and i'd like to back him up
please..
www.animenfo.com
or
anidb.info
would be useful to hundreds of people!
vicanna
dvdgo.com
Post by vicanna »
esta en ingles y en español,con todo lujo de detalles (very good)
vicanna
Post by vicanna »
[REQ] [ES] http://www.cineol.net
Someone (spanish people) can make a script from this page?
DarkSoul
[DE] www.cinema.msn.de
Post by DarkSoul »
Hat jemand Lust und Zeit ein Script für www.cinema.msn.de zu erstellen?
Could someone do a Script für www.cinema.msn.de, please?
