Little error when starting AMC
konfu
Post by konfu »
Hello
When I start AMC for the first time (after a boot of the pc or something else) everything works fine.
Then I put a dvd in my drive and import the movie in AMC. When I'm done, I close AMC, put the dvd out of my drive and everything worked great.
Now when i start AMC for a second time, a little error box appears saying this:
Ant Movie Catalog 3: MovieCatalog.exe - No Disc
There is no disc in the drive.
abort - retry - cancel
Is there any way to solve this little buggie ? :)
Everything else runs smooth and a big :grinking: antp for all your work
That sometime happens, but I do not know why.
A solution is to edit moviecatalog.xml with notepad and delete the DVD path from it (do a search in the file).
To prevent this from happen you can drag & drop the files from Windows Explorer instead of using the "get information from file" menu.
konfu
Post by konfu »
hey antp
i did what u said and the error is gone :D
i replaced this line from MovieCatalog.xml:
<GetFromFiles Type="1" Path="G:\movie\"/>
into this one
<GetFromFiles Type="0" Path="G:\movie\"/>
it still works using the drive and after opening AMC a second time without the use of the drive the error has magically disappeared :D
thx a lot for the help :grinking:
