Designer in mm
GoofySGR
Designer in mm
Post by GoofySGR »
I want to print on Labels for CD Covers.
The Label is 5.5 mm high, but i can the band high only 5.28mm
or 5.56 mm high (i think it comes from the Translation from inch to mm).
How can i switch the Band high in the Designer to a high of 5.5mm???
Thank you
PS: Sorry for my terrible english
Sorry, but considering the size of 1 mm (millimeter, not centimeter) I wonder what's the problem of not being able to specify 5,5mm instead of 5,56... (so the difference is 0,06mm)
GoofySGR
Post by GoofySGR »
There are 48 Labels on A4 Letter.
So 48 * 0,06 = 2,88 cm.
There is no resolution because i can't get the
high of 5.5mm.
http://www.avery-zweckform.com/de1/prod ... _stanz.gif
You can see the Label on click to the link
Thx
GoofySGR
2,88 mm, not 2.88 cm
GoofySGR
Post by GoofySGR »
OK,
not 2.88cm but 2.88mm is a half Etikett,
so i can't print on it.
GoofySGR
Sorry but I can't do anything to that.
The printing designer & engine is not made by me.
GoofySGR
Post by GoofySGR »
ok,
thx
GoofySGR
