New export options ?
Would you be interested in this implementation ?
damn, yes !
4
80%
what for ?
0
No votes
what are you talking about ?!?!?
1
20%
Total votes: 5
rangoon
Post by rangoon »
Hi antp and evrybody,
I have a problem when exporting image file names :
the name are exactly as the movie title, including special caracters (é,à,è, ,-,&,...).
My question are :
- could it be possible to have filename "normalized" for exportation ?
- could it be possible to have movie title XML compliant for exportation (i.e. : & become & and so on).
- could it be possible to have a new icon "XML" as for "HTML", it would ease the export and allow not to manually fake XML via HTML ! :hihi:
Thanks ! ;)
well for XML there is the File -> Save As that will generate a valid file :p (well, it should do it)
I should make the export a little better, I will do not, but the only thing that is not sure yet is "when ?" :p
What I'd like to do would be an export that could be done with zipped templates.
For exemple, a template would be composed of :
- a PNG file containing a screenshot (so the user can select the export to do with a picture instead of a name)
- a text file with info, readme, etc.
- a config file that says to the program which file it has to fill, which files it has to copy, etc.
