Making Ant Movie Catalog more movie player friendly
My suggestions center around making the program more friendly as a front end for a movie player for DivX movie files stored on a hard drive, not CDs.
Things that would make this easier:
Store the full path name of the movie file (when using Get Information from a File)
Have an easy way to play the movie file
Allow a script to be entered -- to be executed when the movie is played (this would allow it to support many players)
Also allow this info to be exported to the HTML to provide an alternate way to view the available moves and launch the viewer.
Cheers!
I may add that... I'll see what I can do for the next version, thanks for the suggestion.
Great. And thanks for the great software!
Check out "script & templates" section topic: Template to view movie info by category. You can launch divx movies right from the exported html! Unfortunatly you can only watch movies from cd i think.
