Customized datetimeoriginal for Exif possible?
hausl78
Post by hausl78 »
Hello,
is it possible to rename JPGs to %datetimeoriginal% but in an customized format?
%datetimeoriginal% is "2017-08-18 18-29-55.jpg"
Thank you!
Juergen
hausl78
Re: Customized datetimeoriginal for Exif possible?
Post by hausl78 »
Update: I made it now via a workaround.
1: Use the default format from the exif function
2: Make a replace via RegEx
and those as a batch, works fine.
Not possible in one action currently, but using regular expressions you can easily change the format in a second pass (after the exif renaming).
e.g. with this expression:
(.*)(\d{4})-(\d{2})-(\d{2}) (\d{2})-(\d{2})-(\d{2})(.*)
and this new name:
$1$2-$3-$4_$5.$6.$7.$8
you should achieve what you want
(to be tested first ;) )
edit: you replied while I was replying, so we came at the same conclusion :D The code here can still be useful if other people need it too
