New Feature
LMNOP
New Feature
Post by LMNOP »
While it will seem a weird one, an inventory feature.
Where if you have a scanner, you could scan all your film's, and the database could tell you if you have any missing. (from the media labels)
I share a house with a few people, so this would come in useful.
Not sure how hard it would be?
:hihi: :lol: Cheers
What do you mean by "scan" ?
scan = type in the UPC barcode either by hand or with a barcode scanner.
well, why not, I'll see that later since it is something that only few people use, and that I will never use.
JoelR
Adding Barcode capability ??
Post by JoelR »
Hi Gent,
I also see a great added value in having a barcode reader capability added in the future, especially if the volume of activity is high...
I already installed a barcode reader on the serial port and wrote a small interface to convert RS232 port input to the current field. It is somehow working, but the process is no simple :
1/ In the search screen I click on search window, then scan the DVD codebar
2/ Then I move in main screen, click in user field and scan user name
3/ Then I must click and date and mark the small box (used as borrow date)
4/ for returning a dvd process is almost identical
So, not easy as you can see as I must use both barcode, keyboard and mouse... Already working, but some room to improve...
I don't know much work it is to have this implemented. Anyway, the software is so nice so far, I cannot personnally complain about anything...
Cheers,
Joel
lkjww
UPC SCAN MODIFICATION
Post by lkjww »
Here is a copy of the gross hack i made to the IMDB script to support UPC code lookups Hope It helps someone.....
FILE : UPC_IMDB_LARGEPIC.ifs
// GETINFO SCRIPTING
// UPC BASED IMDB (US) import - click "Editor" tab to change options
   To change the options, go to the "GetOption"
   and "CanSetField" functions
 *      IMDB (US), http://us.imdb.com              *
 *  (c) 2002-2005 Antoine Potten                   *
 *                          software@antp.be       *
 *  Based on the script made for version 3.x by    *
 *  Antoine Potten, Danny Falkov, Kai Blankenhorn, *
 *  lboregard, Ork, Trekkie, Youri Heijnen         *
 *  For use with Ant Movie Catalog 3.4.3           *
 *  www.antp.be/software/moviecatalog              *
 *  This program is free software; you can         *
 *  redistribute it and/or modify it under the     *
 *  terms of the GNU General Public License as     *
 *  published by the Free Software Foundation;     *
 *  either version 2 of the License, or (at your   *
 *  option) any later version.                     *
program IMDB;
// ***** Here you can change the options of the script *****
function GetOption(OptName: string): Integer;
  case OptName of
    'ImageKind': Result := 2;
          0=No image
          1=IMDB small image, from the main movie page
          2=IMDB large image if found easily, else small image
          3=First search for Amazon large image, then IMDB large one, then IMDB small image if other failed
          4=First search for Amazon large image, then directly take IMDB small image if the first one failed
          5=IMDB large image if found easily, else search for Amazon large image, then take IMDB small image if others failed
    'BatchMode': Result := 0;
          0=Normal working mode, prompts user when needed
          1=Does not display any window, takes the first movie found
    'PopularSearches': Result := 1;
          0=Do not use the popular searches page, directly show full search results
          1=Show popular searches first, I'll click on "Find more" if needed
    'ActorsLayout': Result := 0;
          0=Only actor names, separated by commas
          1=Only actor names, separated by linebreaks
          2=Actors names with character names between parenthesis separated by commas
          3=Actors names with character names between parenthesis separated by linebreaks
          4=Actor names like on IMDB page, with "...." and separated by linebreaks
    'MultipleValuesCountry': Result := 0;
          0=Only take first value for Country
          1=Take full list, separated by commas
          2=Take full list, separated by slashes
    'MultipleValuesCategory': Result := 0;
          0=Only take first value for Category
    'MultipleValuesLanguages': Result := 0;
          0=Only take first value for Languages
    'DescriptionSelection': Result := 2;
          0=Take the short summary, from main page (faster)
          1=Show a list of available summaries
          2=Take the longest summary
    'GetTagline': Result := 0;
          0=Do not get tagline
          1=Put it in Description field, before the summary
          2=Put it in the Comment field, before the comments
// Here you can specify which fields can be modified.
// Simply remove a field from the list if it cannot be modified
function CanSetField(fieldID: Integer): Boolean;
  case fieldID of
    fieldNumber,
    fieldMedia,
    fieldMediaType,
    fieldSource,
    fieldDate,
    fieldBorrower,
    fieldRating,
    fieldOriginalTitle,
    fieldTranslatedTitle,
    fieldDirector,
    fieldProducer,
    fieldCountry,
    fieldCategory,
    fieldYear,
    fieldLength,
    fieldActors,
    fieldURL,
    fieldDescription,
    fieldComments,
    fieldVideoFormat,
    fieldVideoBitrate,
    fieldAudioFormat,
    fieldAudioBitrate,
    fieldResolution,
    fieldFrameRate,
    fieldLanguages,
    fieldSubtitles,
    fieldSize,
    fieldDisks:   Result := True;
    Result := False;
  MovieURL: string;
  MovieNumber: string;
  MovieUPC: string;   //UPC ADD IN
  RemainingText: string;
    when calling...     this variable contains...
    TextBefore          the text after SearchText
    TextBetween         the text after AfterText
// ***** Like the Pos function, but returns the last occurence instead of the first one *****
/// UPC ADD INS
  Result := -1;
  if StartAt < 0 then
    StartAt := 0;
      Result := i;
function AnalyzeUPCPage(Address : string): string;
   Page : TStringList;
   LineNr, BeginPos, EndPos : Integer;
   Line, Value : string;
   LineNr := FindLine('Description', Page, 0);
   if LineNr > -1 then
     BeginPos := LineNr;
     if BeginPos > -1 then
       BeginPos := BeginPos + 29;
     EndPos := pos('</td></tr>', Line);
     //if EndPos = 0 then
      // EndPos := pos('(', Line);
     Value := copy(Line, BeginPos -2, EndPos - BeginPos +2);
     HTMLDecode(Value);
     Result := Value;
function GetMovieTitleFromUPC(UPC : string): string;
   Result := AnalyzeUPCPage('http://www.upcdatabase.com/item.pl?upc=' + UPC);
function LastPos(ASearch: string; AText: string): Integer;
  CurPos, PrevPos: Integer;
  PrevPos := 0;
  CurPos := Pos(ASearch, AText);
  while CurPos > 0 do
    if PrevPos = 0 then
      PrevPos := CurPos
      PrevPos := PrevPos + CurPos + Length(ASearch) - 1;
    Delete(AText, 1, CurPos + Length(ASearch) - 1);
  Result := PrevPos;
{    Returns the text before SearchText, but not before BeginLimit (if it is not empty),
    It takes the last occurence of BeginLimit found before the position of SearchText  }
function TextBefore(WholeText: string; SearchText: string; BeginLimit: string): string;
  FoundPos, PrevPos: Integer;
  WorkText: string;
  Result := '';
  FoundPos := Pos(SearchText, WholeText);
  if FoundPos = 0 then
    Exit;
  WorkText := Copy(WholeText, 1, FoundPos - 1);
  RemainingText := Copy(WholeText, FoundPos + Length(SearchText), Length(WholeText));
  if BeginLimit <> '' then
    FoundPos := LastPos(BeginLimit, WorkText);
      Exit
      FoundPos := FoundPos + Length(BeginLimit);
    FoundPos := 1;
  Result := Copy(WorkText, FoundPos, Length(WorkText));
// ***** Returns the text after SearchText *****
function TextAfter(WholeText: string; SearchText: string): string;
  FoundPos: Integer;
  Result := '';
    Exit;
  Result := Copy(WholeText, FoundPos + Length(SearchText), Length(WholeText));
{    Returns the text between BeforeText and AfterText (without these two strings),
     It takes the first AfterText occurence found after the position of BeforeText  }
function TextBetween(WholeText: string; BeforeText: string; AfterText: string): string;
  FoundPos: Integer;
  WorkText: string;
  Result := '';
  FoundPos := Pos(BeforeText, WholeText);
    Exit;
  WorkText := Copy(WholeText, FoundPos + Length(BeforeText), Length(WholeText));
  FoundPos := Pos(AfterText, WorkText);
    Exit;
  Result := Copy(WorkText, 1, FoundPos - 1);
  RemainingText := Copy(WorkText, FoundPos + Length(AfterText), Length(WorkText));
// ***** analyzes the results page that asks to select a movie from a list *****
  PageText: string;
  Value: string;
  PageText := GetPage(Address);
  if pos('<title>IMDb', PageText) = 0 then
    AnalyzeMoviePage(PageText)
        ShowMessage('No movie found for this search');
      Exit;
      Value := TextBefore(PageText, '<ol>', '<b>');
      if Value <> '' then
        HTMLRemoveTags(Value);
        HTMLDecode(Value);
        PickTreeAdd(Value, '');
      Value := TextBetween(PageText, '<ol>', '</ol>');
      PageText := RemainingText;
    until not AddMovieTitles(Value);
    Value := TextBefore(PageText, '"><b>more titles</b></a>', '<a href="');
    if Value <> '' then
      PickTreeMoreLink('http://us.imdb.com' + Value);
      AnalyzeResultsPage(Address);
// ***** adds the titles contained in <ol>'s items *****
  Value: string;
  Address: string;
  Result := False;
  Value := TextBetween(List, '<li>', '</li>');
  List := RemainingText;
  while Value <> '' do
    Address := 'http://us.imdb.com' + TextBetween(Value, '<a href="', '">');
    HTMLDecode(Value);
    PickTreeAdd(Value, Address);
    Result := True;
// ***** analyzes the page containing movie information *****
procedure AnalyzeMoviePage(PageText: string);
  Value, Value2, Value3, FullValue: string;
  MovieNumber := TextBefore(PageText, '"><option>Your Vote', '<select name="');
  MovieURL := 'http://us.imdb.com/title/tt' + MovieNumber;
  // URL
  if CanSetField(fieldURL) then
    SetField(fieldURL, MovieURL);
  // Original Title & Year
  if CanSetField(fieldOriginalTitle) or CanSetField(fieldYear) then
    Value := TextBetween(PageText, '<title>', '</title>');
    Value2 := TextBefore(Value, ' (', '');
    Value := RemainingText;
    HTMLDecode(Value2);
      SetField(fieldOriginalTitle, Value2);
    if Pos('/', Value) > 0 then
      Value2 := TextBefore(Value, '/', '')
      Value2 := TextBefore(Value, ')', '');
      SetField(fieldYear, Value2);
  // Rating
    Value := TextBetween(PageText, '/rating-stars/', '/rating-vote/');
    Value2 := TextBetween(Value, '<b>', '.');
    if StrToInt(Copy(RemainingText, 1, 1), 0) >= 5 then
      Value2 := IntToStr(StrToInt(Value2, 0) + 1);
    SetField(fieldRating, Value2);
  // Picture
  case GetOption('ImageKind') of
    1:  ImportSmallPicture(PageText);
    2:  if not ImportLargePicture('http://us.imdb.com/gallery/ss/' + MovieNumber) then
    3:  if not ImportAmazonPicture(PageText) then
    4:  if not ImportAmazonPicture(PageText) then
    5:  if not ImportLargePicture('http://us.imdb.com/gallery/ss/' + MovieNumber) then
  // Director
    Value := TextBetween(PageText, '<b class="blackcatheader">Directed by</b>', '</a>');
    Value := TextAfter(Value, '">');
    HTMLDecode(Value);
  // Actors
    Value := TextBetween(PageText, 'ast overview', '</div>');
    if Value = '' then
      Value := TextBetween(PageText, 'redited cast', '</div>');
    if Value <> '' then
      Value := TextAfter(Value, '</tr> ');
      FullValue := '';
      case GetOption('ActorsLayout') of
        0, 1:
          while Pos('<tr>', Value) > 0 do
            Value2 := TextBetween(Value, '<tr>', '</tr>');
            if Pos('<a href="fullcredits">(more)</a>', Value2) > 0 then
            if FullValue <> '' then
            FullValue := FullValue + TextBefore(Value2, '</td>', '');
        2, 3:
            Value2 := TextBetween(RemainingText, '<td valign="top">', '</td>');
            if Value2 <> '' then
              FullValue := FullValue + ' (' + Value2 + ')';
        4:
            FullValue := TextBefore(Value, '</tr><tr><td colspan="2">', '');
            if FullValue = '' then
              FullValue := Value;
            FullValue := StringReplace(FullValue, '</tr>', #13#10);
      HTMLRemoveTags(FullValue);
      HTMLDecode(FullValue);
        1, 3:
          FullValue := StringReplace(FullValue, ', ', #13#10);
  //Country
    SetField(fieldCountry, ImportList(PageText, GetOption('MultipleValuesCountry'), '/Countries/'));
  //Category
    SetField(fieldCategory, ImportList(PageText, GetOption('MultipleValuesCategory'), '/Genres/'));
  // Language
  if CanSetField(fieldLanguages) then
    SetField(fieldLanguages, ImportList(PageText, GetOption('MultipleValuesLanguages'), '/Languages/'));
  //Description
  if CanSetField(fieldDescription) then
    Value := TextBetween(PageText, '<b class="ch">Plot Outline:</b>', '<br><br>');
    if Value = '' then
      Value := TextBetween(PageText, '<b class="ch">Plot Summary:</b>', '<br><br>');
    if Value <> '' then
      SetField(fieldDescription, ImportSummary(Value));
  // Comments
    Value := TextAfter(PageText, '/comments">');
    if Value <> '' then
      Value := TextBetween(Value, '<p>', '</p>');
      Value := StringReplace(Value, #13#10, ' ');
      HTMLDecode(Value);
      Value := Trim(Value);
      while Pos('  ', Value) > 0 do
      while Pos(#13#10, Value) = 1 do
        Delete(Value, 1, 2);
  // Length
    Value := TextBetween(PageText, '<b class="ch">Runtime:</b>' + #13#10, ' ');
    if Value <> '' then
      if Pos(':', Value) > 0 then
        SetField(fieldLength, TextAfter(Value, ':'))
        SetField(fieldLength, Value);
  // TagLine
  if GetOption('GetTagline') > 0 then
    Value := TextBetween(PageText, 'Tagline:</b>', #13);
    if Pos('<a', Value) > 0 then
      Value := TextBefore(Value, '<a', '');
    HTMLDecode(Value);
    if Value <> '' then
      Value := '"' + Value + '"';
      case GetOption('GetTagline') of
        1:
            SetField(fieldDescription, Value + #13#10 + GetField(fieldDescription));
        2:
            SetField(fieldComments, Value + #13#10 + GetField(fieldComments));
// ***** Imports lists like Genre, Country, etc. depending of the selected option *****
function ImportList(PageText: string; MultipleValues: Integer; StartTag: string): string;
  Value, Value2: string;
  if MultipleValues = 0 then
    Value := TextBetween(PageText, StartTag, '</a>');
    Value2 := TextAfter(Value, '">');
    Value := TextBetween(PageText, StartTag, #13#10);
    Value2 := TextBefore(Value, ' <a href="/rg', '');
      Value := Value2;
    HTMLRemoveTags(Value2);
    if MultipleValues = 1 then
      Value2 := StringReplace(Value2, ' / ', ', ');
  HTMLDecode(Value2);
  Result := Value2;
// ***** functions to import the different pictures kinds, depending of the option selected by user *****
function ImportSmallPicture(PageText: string): Boolean;
  Value: string;
  Result := False;
  Value := TextBetween(PageText, '<img border="0" alt="cover" src="', '"');
  if Value <> '' then
    GetPicture(Value, False);
    Result := True;
function ImportLargePicture(Address: string): Boolean;
  Result := True;
  Value := GetPage(Address);
  if SearchForLargePicture(Value, 'Onesheet_text', False) then
    Exit;
  if SearchForLargePicture(Value, 'Onesheet', False) then
    Exit;
  if SearchForLargePicture(Value, 'poster', False) then
    Exit;
  if SearchForLargePicture(Value, 'usposter', False) then
    Exit;
  if SearchForLargePicture(Value, 'text', True) then
    Exit;
  if SearchForLargePicture(Value, 'pos01', True) then
    Exit;
  if SearchForLargePicture(Value, 'KeyArt', True) then
    Exit;
  Address := TextBetween(Value, 'There are ' + #13#10 + '<a href="', '">');
  if Address <> '' then
    Result := ImportLargePicture('http://us.imdb.com' + Address)
    Result := False;
function SearchForLargePicture(PageText: string; Name: string; PartialName: Boolean): Boolean;
  Value: string;
  Result := False;
  if PartialName then
    Value := TextBefore(PageText, Name + '.jpg', '/');
    if Value = '' then
      Exit
      Name := Value + Name;
  Value := TextBefore(PageText, 'th-' + Name + '.jpg', 'src="');
  if Value <> '' then
    GetPicture(Value + Name + '.jpg', False);
    Result := True;
function ImportAmazonPicture(PageText: string): Boolean;
  Result := False;
  Value := TextBefore(PageText, '" title="DVD available', '<a href="');
  if Value = '' then
    Exit;
  PageText := GetPage('http://us.imdb.com' + Value);
  if Pos('unable to find exact matches', PageText) > 0 then
    Exit;
  if Pos('You may also be interested in these items...', PageText) > 0 then
    PageText := TextBefore(PageText, 'You may also be interested in these items...', '');
  Value := TextBefore(PageText, 'TZZZZZZZ.jpg', '<img src="');
  if Value = '' then
    Value := TextBefore(PageText, 'THUMBZZZ.jpg', '<img src="');
  if Value <> '' then
    GetPicture(Value + 'LZZZZZZZ.jpg', False);
    Result := True;
// ***** Gets summaries for the movie, based on the plot outline given in parameter (that contains the URL to more summaries) *****
function ImportSummary(PlotText: string): string;
  Address, Value, Value2, PageText, Longest: string;
  Address := TextBetween(PlotText, '<a href="/rg/title-tease/plotsummary', '">(more)</a>');
  if (Address = '') or (GetOption('DescriptionSelection') = 0) then
    Result := Trim(TextBefore(PlotText, '<a href="/rg', ''));
    if Result = '' then
      Result := Trim(PlotText);
    HTMLRemoveTags(Result);
    HTMLDecode(Result);
    PageText := GetPage('http://us.imdb.com/rg/title-tease/plotsummary' + Address);
    PickListClear;
    Longest := '';
    Value := TextBetween(PageText, '<p class="plotpar">', '</p>');
      HTMLDecode(Value);
      if Length(Value) > Length(Longest) then
        Longest := Value;
      PickListAdd(Trim(Value));
    if (GetOption('BatchMode') = 1) or (GetOption('DescriptionSelection') = 2) then
      Result := Longest
      if not PickListExec('Select a description for "' + GetField(fieldOriginalTitle) + '"', Result) then
        Result := '';
// ***** beginning of the program *****
  if CheckVersion(3,4,3) then
    //MovieName := GetField(fieldOriginalTitle);
    //if MovieName = '' then
     // MovieName := GetField(fieldTranslatedTitle);
      if not Input('UPC Import', 'Enter the UPC of the movie:', MovieUPC) then
        Exit;
        MovieName := GetMovieTitleFromUPC(MovieUPC);
        //ShowMessage('Detected Movie Title : ' + MovieName);
        if (MovieName = '') or (MovieName = '(unknown)') then
        Input('UPC Import', 'Upc Unknown : Please Type the Title.', MovieName);
    if MovieName <> '' then
      if Pos('imdb.com', MovieName) > 0 then
        AnalyzeResultsPage(MovieName)
        MovieName := StringReplace(MovieName, '&', 'and');
        if (GetOption('BatchMode') = 1) or (GetOption('PopularSearches') = 1) then
          AnalyzeResultsPage('http://us.imdb.com/find?tt=1;q=' + UrlEncode(MovieName))
          AnalyzeResultsPage('http://us.imdb.com/find?more=tt;q=' + UrlEncode(MovieName));
      DisplayResults;
    ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 3.4.3)');
Nice, I did not know this site 'upcdatabase.com' :)
I'll add it as option for the IMDB script rather than making a second script ;)
fstcommander
Help with this script
Post by fstcommander »
I tried it. I got to rename
  • function GetOption(OptName: string): Integer; and
I place a "n" before the name because I receive and error.
after that start to run. but know it got stop in line 193
it look like it not found the info. I'm usin the UPC 025195040075.
a lilltle help will be great
thanks in advance
[/list]
Because now GetOption is integrated to the program, this script is rather old.
And FindLine is part of a function library, but it does not seem used by this script (but it is by IMDB - in case you used that with current IMDB script).
This remind me that I still haven't done what I said 4 years ago - integrate that search in IMDB search :sleep:
As I have to do some work on the IMDB script the next days, I'll add that function as an option then. Probably next weekend if I find time for this. ;)
fstcommander
UPC SCAN -- help
That sound great!
I'm not an expert using scripts but will do my try.
Any sugestions, will be welcome.
You know how it is. If you do not have a project you don't practice. (at lease my case)
javascript:emoticon(':D')
PD
ANTP,
Thanks, this is a great Application!!! I use it few years ago. Now I'm back!.
For me this is the only improve that the app need!
BAD4U:
I have seen you helping in the forum, my Thanks to you too. javascript:emoticon(':grinking:')
fstcommander
UPC SCAN -- help
Guys:
a little guidance here. I have the script looking for the UPCdatabace.com reading the movie name andso far work great.
Know if i want to do it in batch. I will need to read the media label field. butI'm doing it in this way:
MovieUPC:= GetField(fieldMedialabel);
but it return an UNKNOWN IDENTIFIER.
How should I retrive info from this field.
thanks for the help in advance. I will submitte to you the changes to use the UPC scan
It's named fieldMedia, not fieldMediaLabel ;)
